rob-2 Posted January 5, 2014 Share Posted January 5, 2014 Hey guys, So I've been having that lumpy idle and slight missing between 2-3k under light throttle. https://drive.google.com/file/d/0B5P4wJAjk9AaMGZaTngwT1RRRDg/edit?usp=sharing Based on this log any idea what's going on? Link to comment Share on other sites More sharing options...
rob-2 Posted January 5, 2014 Author Share Posted January 5, 2014 Oh and I just replaced the ocvs. Link to comment Share on other sites More sharing options...
iNVAR Posted January 5, 2014 Share Posted January 5, 2014 I don't see a LV, just a log. On a different note, what's up with your intake temperature having a range of nearly 100F? Let me guess...you're not on the stock intake? And why does your MRP consistently exceed your target boost? You're hitting 16+ but I never see your targets at anything more than 14.4... Link to comment Share on other sites More sharing options...
rob-2 Posted January 5, 2014 Author Share Posted January 5, 2014 How do I pull a learning view? Well it was about 45f out. I stopped a few times to review the logs and the temps rose. I'm stock intake. Does something appear to be wrong with my tune? Link to comment Share on other sites More sharing options...
Gex Posted January 5, 2014 Share Posted January 5, 2014 Interesting. Stock bpv? I'm guessing you've cleaned your maf and filter? No vacuum leaks? Link to comment Share on other sites More sharing options...
rob-2 Posted January 5, 2014 Author Share Posted January 5, 2014 Interesting. Stock bpv? I'm guessing you've cleaned your maf and filter? No vacuum leaks? Stock bpv. Cleaned maf. New paper filter. No leaks I am aware of. Slight rough and low idle in gear and what feels like a miss fire between 2-3k light throttle in 5 gear. The misfire feeling, idle and knocks concern me. What do I tell my tuner? Link to comment Share on other sites More sharing options...
Gex Posted January 5, 2014 Share Posted January 5, 2014 Coil packs are all fine I'm assuming. I recall a few threads about the stock bpv sticking open and causing similar symptoms. Might just pop it off and see if it sticks. Only takes 5 mins Link to comment Share on other sites More sharing options...
iNVAR Posted January 5, 2014 Share Posted January 5, 2014 How do I pull a learning view? Well it was about 45f out. I stopped a few times to review the logs and the temps rose. I'm stock intake. Does something appear to be wrong with my tune? I can't really tell from what you've logged and without looking at your tune. You should be wondering why you exceed your boost targets though... They're targets for a reason. Are you running a MBC? You logged the wrong WGDC parameter. You logged the max. You pull a LV by running the LV program, or you pull it from RR under one of the menus if you have the latest version of it. Or you search! *kick* You've been here long enough to know. Link to comment Share on other sites More sharing options...
rob-2 Posted January 6, 2014 Author Share Posted January 6, 2014 Coil packs are all fine I'm assuming. I recall a few threads about the stock bpv sticking open and causing similar symptoms. Might just pop it off and see if it sticks. Only takes 5 mins I think it's ok but how would I test it? Link to comment Share on other sites More sharing options...
rob-2 Posted January 6, 2014 Author Share Posted January 6, 2014 I can't really tell from what you've logged and without looking at your tune. You should be wondering why you exceed your boost targets though... They're targets for a reason. Are you running a MBC? You logged the wrong WGDC parameter. You logged the max. You pull a LV by running the LV program, or you pull it from RR under one of the menus if you have the latest version of it. Or you search! *kick* You've been here long enough to know. MBC? Master boost controller? No. LV and I are fighting. What parameters should I log? How concerning is being 1.6 psi over target regularly? Link to comment Share on other sites More sharing options...
iNVAR Posted January 6, 2014 Share Posted January 6, 2014 Manual Boost Controller. You're not supposed to log with LV. YOu just run it and take a screenshot and post it. Search damnit!! 1.6 over consistently isn't normal. A spike is fine if you don't knock, but you're not spiking. You hit 16+ and STAY up there for a while. Properly working boost control shouldn't be like that. Targets are targets for a reason. They should be something your BC system tries to hit and maintain and stay near. Link to comment Share on other sites More sharing options...
rob-2 Posted January 6, 2014 Author Share Posted January 6, 2014 Manual Boost Controller. You're not supposed to log with LV. YOu just run it and take a screenshot and post it. Search damnit!! 1.6 over consistently isn't normal. A spike is fine if you don't knock, but you're not spiking. You hit 16+ and STAY up there for a while. Properly working boost control shouldn't be like that. Targets are targets for a reason. They should be something your BC system tries to hit and maintain and stay near. I found the app online to run on its own. Going to pull it when I get down to the car in this AM. The boost error is all over the place. While accelerating mid-rpm I'm getting 1.6 over, but towards the top end I'm getting up to 5psi error. At the top end it appears the ECU is calling for 14.4 from the turbo but getting 11psi. While this is happening it appears I'm getting knock. The ECU is adding 3-6.5 degrees of corrective timing under "Knock Correction Advance (degrees)" This is a problem right? Link to comment Share on other sites More sharing options...
rob-2 Posted January 6, 2014 Author Share Posted January 6, 2014 LV won't connect to my ECU though romraider will. Link to comment Share on other sites More sharing options...
rob-2 Posted January 6, 2014 Author Share Posted January 6, 2014 I'm being told the difference between target and actual boost is because we're at 4500 feet. Does this make sense? Link to comment Share on other sites More sharing options...
iNVAR Posted January 7, 2014 Share Posted January 7, 2014 Yes, if you're at elevation that perfectly explains it. As far as knock goes, no, you're interpreting it wrong. Knock Control Advance is really just Dynamic Advance (adds/subtracts timing as it sees fit.) Positive number means you're adding timing (good). Negative means you're retarding timing (bad.) Boost error is supposed to go all over the place when you're accelerating, decelerating, braking, etc. When you're accelerating hard at WOT, the boost error is supposed to decrease though in general, because turbo dynamics will make adjustments. Link to comment Share on other sites More sharing options...
rob-2 Posted January 7, 2014 Author Share Posted January 7, 2014 Ok perfect. Matt my tuner thinks I might have a leak somewhere. Causing the slightly rough idle and stumble between 2-3k under light throttle. Why I'm consuming 1 qt per 2500 miles is still a mystery. Link to comment Share on other sites More sharing options...
rob-2 Posted January 8, 2014 Author Share Posted January 8, 2014 They replaced my PCV. So we'll see how that addresses things. It was the new one I had on the old block before they rebuilt it. Told me it had some stick to it. At this point I will just drive the darn thing. Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 8, 2014 Share Posted January 8, 2014 Stock DP and UP or aftermarket? Boost creep could be the issue for your boost being all over the place. Look here: http://forums.nasioc.com/forums/showthread.php?t=477715 Link to comment Share on other sites More sharing options...
rob-2 Posted January 8, 2014 Author Share Posted January 8, 2014 Stock DP and UP or aftermarket? Boost creep could be the issue for your boost being all over the place. Look here: http://forums.nasioc.com/forums/showthread.php?t=477715 After market. Catless invidia up and down. Link to comment Share on other sites More sharing options...
