JJay03 Posted December 26, 2013 Share Posted December 26, 2013 I was looking at buying a donor to swap to a manual. Besides the obvious parts what all is different about the wiring? If I wanted to make it like a factory swap how much of the wiring would I have to swap? Link to comment Share on other sites More sharing options...
johnegg Posted December 26, 2013 Share Posted December 26, 2013 if you are putting a manual trans in an auto trans car, you don't have to swap any wiring harness. you do need to tell the computer it is a manual trans, but that can be done fairly easily, once you know what is needed. Link to comment Share on other sites More sharing options...
JJay03 Posted December 26, 2013 Author Share Posted December 26, 2013 if you are putting a manual trans in an auto trans car, you don't have to swap any wiring harness. you no need to tell the computer it is a manual trans, but that can be done fairly easily, once you know what is needed. Ok thanks I hope I can get the car tomorrow and it hasnt been sold. Link to comment Share on other sites More sharing options...
JJay03 Posted January 8, 2014 Author Share Posted January 8, 2014 I made a deal for the donor car its a 97 and mine is a 98. I heard something about the cruise control is different is that true? Wondering how much of the wiring ill need to pull from the donor. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 8, 2014 Share Posted January 8, 2014 you need to wire in the clutch switch (optional) and starter interlock relay into the ignition circuit i opted to make a plug and play harness so i could throw in a AT if I ever needed to again: http://i161.photobucket.com/albums/t232/wakeboardingguy/Black%20Subaru/IMG_20130419_185742_650.jpg other than that, grab the AT harness and a foot or so of it's wiring, you can get your cruise to work with the MT Link to comment Share on other sites More sharing options...
Zues Marine Posted January 8, 2014 Share Posted January 8, 2014 then add a pin to slot 85 on the ECU (#20 on the '95) and ground it that's your at/mt id pin Link to comment Share on other sites More sharing options...
JJay03 Posted January 8, 2014 Author Share Posted January 8, 2014 So im guessing it would be more of a pain to swap harnesses then to just make a plug n play harness. Im just trying to find a detailed walk through of what all I need to do. Sure im going to need some wiring diagrams too. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 8, 2014 Share Posted January 8, 2014 http://forums.nasioc.com/forums/showthread.php?t=2461780 Link to comment Share on other sites More sharing options...
JJay03 Posted January 9, 2014 Author Share Posted January 9, 2014 What about the ABS is it different between the manual and auto cars? Link to comment Share on other sites More sharing options...
Zues Marine Posted January 9, 2014 Share Posted January 9, 2014 I'm not 100% but speaking from my own experience, it all works the way it should after I finished the swap, I didnt have to mess with anything ABS related Link to comment Share on other sites More sharing options...
JJay03 Posted January 20, 2014 Author Share Posted January 20, 2014 Was looking at the wiring some today and was thinking about taking the ecu and harness and using it in my car since it had all the connectors to the trans. The other harness under the hood looks to be used for the abs/evap/cruise stuff like that. On the auto that harness also plugs into the trans. I might just keep that 2nd harness on my car and forget about having the abs work cause I dont like it anyway. If I switched out both harnesses im not sure how that would work since the 97 has the evap under the hood that runs off the second harness and the connector for the brake level is different so not sure if i could just splice that or not. Still open to options but I think it would definetly be best to use the ecu and the engine harness off the 97 which looks like it will plug into the harness alrdy on the intake of my 98 I hope. Link to comment Share on other sites More sharing options...
JJay03 Posted January 20, 2014 Author Share Posted January 20, 2014 Been trying to do research all day at work. I think ill just use my 98 wiring and try to make some plug n play harnesses. Im still not sure what all wires need to connect to where tho. Trying to get some help from someone who has done this before. Link to comment Share on other sites More sharing options...
