cobb Posted December 22, 2013 Share Posted December 22, 2013 Every once and a while after the cars warmed up and I attempt to re start it, the engine stays at a low idle and kinda "diesels" for a couple seconds until I give it a couple taps of the throttle and it smooths out. It doesn't do this every time I do a warm start just sometimes. Any thoughts? I've also replaced all my vacuum lines to eliminate that and it still does it. But like I said it doesn't do it every time so it's hard to know when to take a video. Link to comment Share on other sites More sharing options...
12sechatch Posted December 22, 2013 Share Posted December 22, 2013 It might sound weird, but check your battery terminals and your grounds. These cars react very odd when there is a bad connection somewhere. Link to comment Share on other sites More sharing options...
cobb Posted December 23, 2013 Author Share Posted December 23, 2013 Hmmm I could do that, I just moved my passenger side ground to the head like the drivers side is, it was mounted on the heat shield for some reason. I noticed it yesterday when replacing my exhaust stud that was stripped out. Link to comment Share on other sites More sharing options...
