adot111 Posted December 18, 2013 Share Posted December 18, 2013 Does any one know the hub bolts torque specs? I found the service manual shows 47.9ft-lb, I don't know it is right or not, the number seems low for me. I doubt it because when I check other torque spec on the manual, the axle nut is 140ft-lb, the wheel nut is 66ft-lb, which are most people set 177ft-lb, and 90ft-lb. So, I am confuse now, what is torque specs for those 4 bolts? Thanks advance Link to comment Share on other sites More sharing options...
ras06LGT Posted December 18, 2013 Share Posted December 18, 2013 Per the service procedure 47.9 ft-lb is correct for the hub bolts (both front and rear). The axle nut is 162 ft-lb for the front axle, 177 ft-lb for the rear axle, and the lug nuts are 81.1 ft-lb all around. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2013 Share Posted December 18, 2013 Use anti sieze compound and the threads. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
adot111 Posted December 18, 2013 Author Share Posted December 18, 2013 Ok, Thanks guys Link to comment Share on other sites More sharing options...
