Underground Posted December 3, 2013 Share Posted December 3, 2013 Hey guys. I picked up a set of 06 WRX TR seats for my 99 Legacy L wagon. Once I got the stock seat out of the passenger side (one of the bolts was stuck like a MoFo), I placed the WRX seat in just to test fit. I doesn't seem like its lining up right. The holes are close, but it seems like one of the mounting spots won't work with these seats. If i push down the seat kinda leans to the side. Is there something I need to change or am I just a dope and didn't do something correctly? Thanks for any help! Link to comment Share on other sites More sharing options...
kurtis9813 Posted December 3, 2013 Share Posted December 3, 2013 When I put 02 wrx seats in my 97 GT I had trouble lining the holes up. It's tricky but I finally got it to line up after playing with it for awhile. I'm not an expert on what seats fit into which cars, but I thought any 02-07 impreza seats fit in 95-99 legacys Link to comment Share on other sites More sharing options...
Underground Posted December 3, 2013 Author Share Posted December 3, 2013 From what I've read over time, people swap them all the time. I've been going through the second gen sub for hours now and still no info... just a lot of pics of them installed! Link to comment Share on other sites More sharing options...
Underground Posted December 4, 2013 Author Share Posted December 4, 2013 8 hours later and I've found nothing (except a headache lol). I wonder if my rails are bent on the WRX seats.. Haven't seen anyone else having an issue. Link to comment Share on other sites More sharing options...
InsertEnigmaHere Posted December 4, 2013 Share Posted December 4, 2013 http://legacygt.com/forums/showthread.php/wrx-seat-swap-trouble-201924.html I had issues putting mine in a while back. If I recall, the wrx seat uses 4 bolts while the Legacy seat is mounted with 5 bolts. One of them has a weld nut that often breaks loose and spins with the bolt. That particular bolt is the one located on the lower rear part of the seat rail, going into the driveshaft hump. Hope this helps. Link to comment Share on other sites More sharing options...
Underground Posted December 4, 2013 Author Share Posted December 4, 2013 Yea.. I learned the hard way about the one that breaks free. It happened to me on Saturday. Lol. A LOT of pissing and moaning occurred. The one I'm having a problem seems to be the front right bolt hole is no where close. Thanks for the help though! Link to comment Share on other sites More sharing options...
spooln30 Posted December 4, 2013 Share Posted December 4, 2013 What about swapping the seat brackets? They might be close enough to slightly modify to swap. Link to comment Share on other sites More sharing options...
Zues Marine Posted December 4, 2013 Share Posted December 4, 2013 Try screwing the front bolts in first Link to comment Share on other sites More sharing options...
Underground Posted December 4, 2013 Author Share Posted December 4, 2013 Apparently Saturday at the shop was just one of those days where nothing would go right. Came in today and finished up all customers shit, then jumped back into the seat dilemma. I threw the passenger seat in and leaned hard on it.. holes got closer. Did it again and I could see the light at the end of the tunnel! So anyway.. Im a putz. And the passenger seat is in. Now I have to fight with the drivers side and hope that fifth bolt on the Leggys in the transmission tunnel doesn't brake free like passenger side did... Thanks for all the tips guys! Link to comment Share on other sites More sharing options...
98 OB RNV Posted December 7, 2013 Share Posted December 7, 2013 I'm glad I ran into this post. I just picked up a set of seats from a 07 OB sport and plan to do the same thing. So did you get the drivers seat in without any modifications? Link to comment Share on other sites More sharing options...
spooln30 Posted December 7, 2013 Share Posted December 7, 2013 What about the bracket swap? Link to comment Share on other sites More sharing options...
98 OB RNV Posted December 7, 2013 Share Posted December 7, 2013 Im going to start by taking off the the passenger side seat today and measuring both brackets before I go crazy on it. Link to comment Share on other sites More sharing options...
98 OB RNV Posted December 7, 2013 Share Posted December 7, 2013 Well, good news bad news with my swap. Good news is that it was a direct swap from a 07 Impreza. Bad news, it sits an inch to inch 1/2 higher. Not good for 2 long legged 6 footers. I'm not sure if the bracket change would make it sit lower. By looks of it the bracket change will be a pain. Has anyone tried this? Link to comment Share on other sites More sharing options...
awilkie84 Posted December 10, 2013 Share Posted December 10, 2013 I have Outback seats in my Legacy. They have a bracket with up/down adjustment. Don't know if the Impreza does, but it makes it nice for my 6'2" ass to fit without hitting my head. Link to comment Share on other sites More sharing options...
Zues Marine Posted December 10, 2013 Share Posted December 10, 2013 Why are y'all swapping brackets? All the seats mentioned in this post are a direct bolt in... I have Fozzy seats in my wagon and while it is a couple inches higher, I have never had an issue with my dome hitting the roof, lol Also 6'1". Link to comment Share on other sites More sharing options...
98 OB RNV Posted December 10, 2013 Share Posted December 10, 2013 The brackets from the Legacy are close but do not bolt up without major mods to mounting points. So, yes the Preza seats are a direct bolt on, there is an additional height on the seats. It is a little weird sitting higher when your used to a lower seat. Link to comment Share on other sites More sharing options...
mailman Posted December 10, 2013 Share Posted December 10, 2013 Are all impreza and wrx seats the same? Will an older impreza seat give me the extra height as well? I'm looking for the height and something not as worn as my 17 year old seat, but I'm not going to pay $200 for it either Link to comment Share on other sites More sharing options...
98 OB RNV Posted December 11, 2013 Share Posted December 11, 2013 The WRX and Impreza seats are very similar on some years and very different on others. Any seats from an Impreza should give an height adjustment and therefore sit a little higher than your older Legacy seats. I picked up both drivers and passengers from an 07 Impreza for $200 and they are very much worth it. Link to comment Share on other sites More sharing options...
Zues Marine Posted December 11, 2013 Share Posted December 11, 2013 The brackets from the Legacy are close but do not bolt up without major mods to mounting points. Which seats are you referring to, specifically? That seems odd from my personal experience; I've had no trouble with a direct bolt in with a variety of seats from fozzys and other impreza-based chassis' up til about 08. Unless I'm interpreting what you're saying wrong ha Link to comment Share on other sites More sharing options...
98 OB RNV Posted December 11, 2013 Share Posted December 11, 2013 If you are trying to use the mounting brackets from one seat to another, for instance my Legacy seat brackets will not fit on the 07 Impreza seats. The mounting points to bolt onto the body of the Legacy are the same though without using the one that bolts to the tranny tunnel. <--that just sounds wrong.. Which seats are you referring to, specifically? That seems odd from my personal experience; I've had no trouble with a direct bolt in with a variety of seats from fozzys and other impreza-based chassis' up til about 08. Unless I'm interpreting what you're saying wrong ha Link to comment Share on other sites More sharing options...
Zues Marine Posted December 11, 2013 Share Posted December 11, 2013 Lol Oh... Yeah I haven't bracket swapped at all Link to comment Share on other sites More sharing options...
twisty Posted December 13, 2013 Share Posted December 13, 2013 do like my friend did when putting 09 import seats into his 1980 caprice (he liked the style and high back buckets from some hyundai) and cut the brackets long-wise and weld them to the new seats. it took a bit of doing, but it came out nice. now he has high back buckets in his hot rod lol. Link to comment Share on other sites More sharing options...
