B_riz0212 Posted December 3, 2013 Share Posted December 3, 2013 replacing my turbo because of oil seals/shaft play. The rubber part of the inlet hose to the intake is beat, so I'm looking for a replacement. Suggestions on brands, what will fit....etc. For instance if one says it fits a 2005 Impreza wrx sti sedan with the same 2.5ltr will it work? Ive put well over a thousand dollars into this car in 2 months, so trying to keep prices down, and it is just a hose/pipe so are they really that different? Thanks in advance. Link to comment Share on other sites More sharing options...
Brian3676 Posted December 3, 2013 Share Posted December 3, 2013 I bought a perrin one. To make it work you had to modify stuff because they make it universal for lgt and wrx. I sold it and got a oem one. Dident feel like screwing around. Link to comment Share on other sites More sharing options...
Nrw Posted December 3, 2013 Share Posted December 3, 2013 My Samco piece is really nice. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2013 Share Posted December 3, 2013 I went with OEM. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
B_riz0212 Posted December 3, 2013 Author Share Posted December 3, 2013 I went with OEM. Any chance you have a part #? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2013 Share Posted December 3, 2013 at the very top of the very first forum is a "opposed forces" web site, You'll find it there once you learn how to use the site. Or call Fredbeans, a Vendor here and order one. The guy's there are great. See the VENDOR link up top on the dark blue bar. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
blongo804 Posted December 3, 2013 Share Posted December 3, 2013 Suggestions on brands, what will fit....etc. For instance if one says it fits a 2005 Impreza wrx sti sedan with the same 2.5ltr will it work? You need '08+ WRX/'05-09 LGT style turbo to directly bolt up to your stock intercooler. '02-07/'04-'14 STI style turbo's won't directly bolt up unless you go to a FMIC setup or do a little intake manifold/throttle body swapping (not worth it). Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2013 Share Posted December 3, 2013 You need '08+ WRX/'05-09 LGT style turbo to directly bolt up to your stock intercooler. '02-07/'04-'14 STI style turbo's won't directly bolt up unless you go to a FMIC setup or do a little intake manifold/throttle body swapping (not worth it). I think hes talking about the black hose under the intake manifold. OP I bolted my turbo on, its easier then useing the studs. Also replace the oil return hose. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
B_riz0212 Posted December 3, 2013 Author Share Posted December 3, 2013 You need '08+ WRX/'05-09 LGT style turbo to directly bolt up to your stock intercooler. '02-07/'04-'14 STI style turbo's won't directly bolt up unless you go to a FMIC setup or do a little intake manifold/throttle body swapping (not worth it). already have the turbo(just another vf40 used with 45k on it) just need the inlet pipe/hose Link to comment Share on other sites More sharing options...
B_riz0212 Posted December 3, 2013 Author Share Posted December 3, 2013 I think hes talking about the black hose under the intake manifold. Yes Link to comment Share on other sites More sharing options...
BadTouch Posted December 3, 2013 Share Posted December 3, 2013 I put the perrin on mine but like brian3676 said i had to change some stuff to make it work. would be easier to find one that is model specific. Link to comment Share on other sites More sharing options...
FJuan Posted December 3, 2013 Share Posted December 3, 2013 On a VF40, I would stay OEM. It's going to be cheaper than most of the aftermarket ones anyway. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
chato Posted December 3, 2013 Share Posted December 3, 2013 I went with a perrin for my 05 and fit wasn't that bad. The BPV inlet is just about 1inch closer to the front of the car than stock, otherwise fit fine. Picked up a Samco BPV hose which had added flexibility over stock and made install easier. Just didn't want to have another stock inlet failure down the road. Link to comment Share on other sites More sharing options...
B_riz0212 Posted December 4, 2013 Author Share Posted December 4, 2013 Thanks all. Went with OEM for now. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
