DonnyJagaru Posted November 28, 2013 Share Posted November 28, 2013 As above, looking to stiffen up the suspension and perhaps go a little lower than stock. I gather I'm looking at springs, shocks & front & rear sway bars. Someone must sell a kit for this I'm thinking? New to Subies. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 29, 2013 Share Posted November 29, 2013 As above, looking to stiffen up the suspension and perhaps go a little lower than stock. I gather I'm looking at springs, shocks & front & rear sway bars. Someone must sell a kit for this I'm thinking? New to Subies. Donny, Welcome to the world of subies. For the most part the shocks/struts/springs for the LGT will bolt onto your car w/o issue. The rear sways and associated parts will also bolt on. Front sway will be specific to the 2.5i since the cross member is different for the non-turbo cars. I would suggest the Epic springs coupled with either KYB GR2/ExcelG struts/shocks which are slightly better than stock or Koni Inserts for shocks/struts. For sways the Whiteline rear sway bar and endlinks will serve you well. I would personally leave the OEM front sway bar in there. Shoot us a msg and we can put together a package for you. -mike Link to comment Share on other sites More sharing options...
