rs6er Posted November 26, 2013 Share Posted November 26, 2013 I am replacing my OEM Bilsteins with HD's. Mechanic says it is recommended to replace the top mounts along with the struts, but I haven't heard of anyone doing this unless they were switching to Spec B top mounts, which I have. Is this correct? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 26, 2013 Moderators Share Posted November 26, 2013 Depending on mileage, yes it's sometimes recommended, but only fro the fronts. The fronts have a bearing in them that can wear over time. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Dujo Posted November 26, 2013 Share Posted November 26, 2013 If they're bent. One of my fronts was no longer flat. Swapped it for new. Link to comment Share on other sites More sharing options...
rs6er Posted November 26, 2013 Author Share Posted November 26, 2013 So, I'm okay with the rears? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 26, 2013 Moderators Share Posted November 26, 2013 So, I'm okay with the rears? Should be. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
iNVAR Posted November 27, 2013 Share Posted November 27, 2013 Rears are usually fine, but they're made of rubber I believe and rubber does age as you know. Replace the fronts. 80K on mine and the fronts were both toast when I did my struts. The bearings were very crunchy. Link to comment Share on other sites More sharing options...
rs6er Posted November 27, 2013 Author Share Posted November 27, 2013 Mine have 63,000 miles. I didn't replace them. They were fine. Link to comment Share on other sites More sharing options...
iNVAR Posted November 27, 2013 Share Posted November 27, 2013 Interesting. The bearings spun completely freely and quietly? Link to comment Share on other sites More sharing options...
rs6er Posted November 28, 2013 Author Share Posted November 28, 2013 Rears only. Link to comment Share on other sites More sharing options...
iNVAR Posted November 28, 2013 Share Posted November 28, 2013 The rears don't have bearings.... edit: Do you mean you kept the rears and replaced the fronts? Link to comment Share on other sites More sharing options...
AZP Installs Posted November 29, 2013 Share Posted November 29, 2013 We usually suggest replacing the fronts if they show any signs of wear due to the bearings, rears should be good until you get to your second or 3rd set of shocks/struts. -mike Link to comment Share on other sites More sharing options...
rs6er Posted November 29, 2013 Author Share Posted November 29, 2013 The rears don't have bearings.... edit: Do you mean you kept the rears and replaced the fronts? I kept the rear top hats and replaced the rear OEM Bilsteins with Bilstein HDs. I didn't do anything in the front. Link to comment Share on other sites More sharing options...
