aktorides Posted November 21, 2013 Share Posted November 21, 2013 I get this error code 3 times in 5 months period time.AT oil temp flashing and immediate I stop the car let it to cool down for 20 second and then everything fine for a while. The car has 58000KM.ATF changed and oil filter as well. I read somewhere in the forum about bad wiring or even a damage turbine speed sensor 2.My mechanic added ATF additive for now reset the TCU and see what happens next!! Any comments will much be appreciate!! Link to comment Share on other sites More sharing options...
aktorides Posted December 20, 2013 Author Share Posted December 20, 2013 Problem gone.Full reset of the ECU and the TCU.If you experiencing power loss or battery change do a full reset first before change any transmission oil or try to open the transmission due to ATF oil temp light flashing or any error codes received Link to comment Share on other sites More sharing options...
aktorides Posted October 12, 2014 Author Share Posted October 12, 2014 Problem finally fixed yesterday! Speed sensor 2 was blown. I could not buy the sensor alone or the valve body wiring harness. The whole valve body was changed with a new one. Link to comment Share on other sites More sharing options...
amp583 Posted September 18, 2017 Share Posted September 18, 2017 Bumping the past - sorry. Aktorides, did you get this work done at the dealer or mechanic? Also, was the valve body modified? I see the 5EAT-S in your details... thanks! Link to comment Share on other sites More sharing options...
realrift Posted January 19, 2019 Share Posted January 19, 2019 Hi, Sorry for the late reply. Just wanted to link to a fix in case someone stumbles across this post. If you have the p1710 code, it is due to "torque converter turbine 2 speed signal circuit malfunction". This is a small HALL effect sensor bolted onto the back of the valve body in the 5eat. In the '08 and up cars it can be replaced individually without needing to replace the entire valve body. I found the fix on subaruoutback forums here: https://www.subaruoutback.org/forums/109-gen-3-2005-2009/499945-repair-p1710-hard-shifts-5eat.html The thread also has a couple of links where you can buy the sensor which is about $100 and looks identical to the stock sensor. There is also a DIY-type fix posted with a generic HALL efect sensor you can get from Amazon. Hope this helps someone. Link to comment Share on other sites More sharing options...
P1710 Posted November 29, 2019 Share Posted November 29, 2019 Hi everyone. I recently went through this frustration with my granddaughter's 2008 Legacy GT. I paid over $200 to get a sensor overnight out of Canada. As a result of that experience I decided to make the sensor available here in the US at reasonable price. You can get it with or without the filter. See links below. Thank you. With filter. https://www.ebay.com/itm/133239156024 Without filter. https://www.ebay.com/itm/133200929693 Link to comment Share on other sites More sharing options...
P1710 Posted August 31, 2020 Share Posted August 31, 2020 Update: I've gotten tons of great feedback on these parts. Thank you to anyone that has purchased to help me keep this going. Please note that the Ebay item number for the sensor with filter has changed to 133417836227. https://www.ebay.com/itm/133417836227 https://www.ebay.com/itm/133200929693 Thanks again! Jerry Link to comment Share on other sites More sharing options...
bergs Posted December 13, 2020 Share Posted December 13, 2020 Update: I've gotten tons of great feedback on these parts. Thank you to anyone that has purchased to help me keep this going. Please note that the Ebay item number for the sensor with filter has changed to 133417836227. https://www.ebay.com/itm/133417836227 https://www.ebay.com/itm/133200929693 Thanks again! Jerry Just wanted the forum to know that I recently ordered the sensor and filter combo from Jerry and shipping was excellent. Parts arrived as described, no hassles whatsoever. Link to comment Share on other sites More sharing options...
whitexc Posted December 13, 2020 Share Posted December 13, 2020 I am confused about the filter. Is this an internal transmission filter? I though that was in the fender well behind the battery. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
bergs Posted December 14, 2020 Share Posted December 14, 2020 Yes, internal filter. The 2005 LGT I owned had a spin on style filter located in the fender. This 2008 has it located inside the transmission housing. Link to comment Share on other sites More sharing options...
whitexc Posted December 14, 2020 Share Posted December 14, 2020 Ahh, thanks for the reply. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
