hobo2701 Posted November 15, 2013 Share Posted November 15, 2013 Just seeing if anyone could help me on this I might be getting a set of 09 spec b oem strut/spring tophats for the winter to keep my coilovers clean will they work even though it's a wagon thx for any help Link to comment Share on other sites More sharing options...
whitetiger Posted November 15, 2013 Share Posted November 15, 2013 yes, have fun. Link to comment Share on other sites More sharing options...
idiot4hire Posted November 15, 2013 Share Posted November 15, 2013 Yep I have spec b stuff on my 05 Link to comment Share on other sites More sharing options...
hobo2701 Posted November 15, 2013 Author Share Posted November 15, 2013 Sweet def don't wanna romp the ohlins this winter if I didn't have to Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2013 Share Posted November 19, 2013 Having a Spec B and a wagon with Koni's and Epics. The wagon handles better. The Spec rides better on rough roads. I have the Koni's set in the middle on the front and one turn off firm on the rear. I would also go with the 1/2 spacer next time. If I had to do it over again. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ScottieBoy Posted November 19, 2013 Share Posted November 19, 2013 I have a question that's around the same idea. I have an 09 2.5i. I'm doing the Koni/Epic setup and I'm looking for strut housings so my car is only out for a few hours rather than a weekend. I found a guy that has a wagon with stock struts. Are the housing on the bl and bp the same? Link to comment Share on other sites More sharing options...
whitetiger Posted November 19, 2013 Share Posted November 19, 2013 I have a question that's around the same idea. I have an 09 2.5i. I'm doing the Koni/Epic setup and I'm looking for strut housings so my car is only out for a few hours rather than a weekend. I found a guy that has a wagon with stock struts. Are the housing on the bl and bp the same? yes, have fun. Link to comment Share on other sites More sharing options...
ScottieBoy Posted November 19, 2013 Share Posted November 19, 2013 Thank you, sir! Link to comment Share on other sites More sharing options...
