kc sly Posted November 10, 2013 Share Posted November 10, 2013 I have 2010 lgt, with 6 speed. Every once in a while when trying to go into reverse the stick doesn't easily engage all the way. But if I just let off clutch and then push in clutch a second time you can put it right into reverse no problem. Anyone else notice this? only 36k on car. Link to comment Share on other sites More sharing options...
PtPixel Posted November 10, 2013 Share Posted November 10, 2013 I've had this with a few previous cars I've had. Pretty sure it's just the teeth of the synchro not mating perfectly - the gear teeth collide with the synchro teeth. By engaging the clutch again the drive train will spin the synchro and will just re-position the teeth so that they do mate properly Link to comment Share on other sites More sharing options...
kc sly Posted November 11, 2013 Author Share Posted November 11, 2013 Thanks!! Link to comment Share on other sites More sharing options...
