trl21068 Posted November 7, 2013 Share Posted November 7, 2013 On my way to work my 2009 legacy overheated. I turned the temp of the heater to high and got cold air. Pulled off the road and saw the overflow was filled and overflowing. Once the fans cold down the radiator all the coolant from the overflow got sucked back into radiator. I hope it's just the thermostat. No heat has me thinking it could be more. Mileage is 72,000. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 7, 2013 Share Posted November 7, 2013 No heat is because all the coolant is gone. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Grimmrican Posted November 7, 2013 Share Posted November 7, 2013 Could be tstat or even the water pump or the heater core. Most likely ur tstat is stuck closed Link to comment Share on other sites More sharing options...
rob-2 Posted November 7, 2013 Share Posted November 7, 2013 air pocket. bleed it. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 7, 2013 Share Posted November 7, 2013 Oh I see its a 2.5i 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
trl21068 Posted November 7, 2013 Author Share Posted November 7, 2013 Dealer called said it needs head gaskets. At least extended warranty is good until April 25 2014. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 7, 2013 Share Posted November 7, 2013 I guess that paid for its self. Good for you. Even at 72k, you may want to have the timing belt and stuff replaced while it's apart. Should just cost you a few hundred in parts but save the $500 in labor on that job. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Kuba23 Posted January 14, 2017 Share Posted January 14, 2017 I had the same problems with my 09 2.5i legacy. I have replaced the radiator, waterpump, thermostat, and head gasket, but it is still overheating. Any suggestions? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted January 14, 2017 Share Posted January 14, 2017 I had the same problems with my 09 2.5i legacy. I have replaced the radiator, waterpump, thermostat, and head gasket, but it is still overheating. Any suggestions? Do your fans come on? Link to comment Share on other sites More sharing options...
scottmcphee Posted January 17, 2017 Share Posted January 17, 2017 Pinching off the heater core supply hose will cause cold air blowing and car will overheat. I know this because I tried this in an attempt to have cold air only in the summer. The HVAC boxes in these cars are blender boxes with a movable flap that directs more or less air flow through hot and cold regions / channels in the box. I wanted to stop all hot coolant flowing through the mixer box so there was no chance of picking up heat in there... the result was cold air... for sure. And the car promptly overheated. Taking the pincher off the hose brought everything back into normal. Coolant NEEDS to flow on the heater core circuit in order for normal engine cooling to happen. Which I think is a bit bizarre. But whatever. Maybe your core supply (or return!) hose is pinched, kinked, or internally blocked or has an air pocket inside that is effectively preventing a flow to happen. Link to comment Share on other sites More sharing options...
apexi Posted January 17, 2017 Share Posted January 17, 2017 I had the same problems with my 09 2.5i legacy. I have replaced the radiator, waterpump, thermostat, and head gasket, but it is still overheating. Any suggestions? Have you tried burping the system to see if there's any extra air in there? I think maybe he said it's unnecessary on the newer models, but I still kinda wonder about air in the system? Link to comment Share on other sites More sharing options...
