chamorudude87 Posted November 5, 2013 Share Posted November 5, 2013 I have a 06 2.5i and just had the clutch replaced, an hour after driving I noticed a chirping sound when I was idling. If I just barely set my foot on the clutch pedal it goes away... I know the throwout bearing was replaced, anyone have this issue in the past? Any ideas? Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 5, 2013 Share Posted November 5, 2013 I have a 06 2.5i and just had the clutch replaced, an hour after driving I noticed a chirping sound when I was idling. If I just barely set my foot on the clutch pedal it goes away... I know the throwout bearing was replaced, anyone have this issue in the past? Any ideas? Sent from my SM-N900T using Tapatalk Take it back to the shop that did the work its chirping there could a be a chance they didnt adjust the clutch pedal travel properly after the re-install. It is a simple adjustment to make on your own but sincce the work is fresh I would take it back and mention it, if they are knowledgeable they should be able to correct it quick. Link to comment Share on other sites More sharing options...
jhow257415 Posted November 15, 2013 Share Posted November 15, 2013 yes I had this too last summer….was throwout bearing as well, had the clutch replaced (had broken teeth on the pressure plate). After the clutch change all went away. Link to comment Share on other sites More sharing options...
SBT Posted November 15, 2013 Share Posted November 15, 2013 Could be as simple as undoing the transmission mount bolts and shifting the trans slightly and re-tightening everything. Also, if that doesn't fix it (and it typically does where clutch chirping is involved), get a small spring, and attach it to the TOB arm and rig it to something close. There's a thread on it. Keyword search "spring, clutch, TOB arm". - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
apexi Posted November 15, 2013 Share Posted November 15, 2013 My car did the same thing after a new clutch was installed. From what I've read on this forum, it's a very common issue. People say it can be fixed by installing a return spring on the clutch fork. http://legacygt.com/forums/showthread.php/chirping-clutch-out-179869.html http://legacygt.com/forums/showthread.php/my-tob-squeal-solution-alt-clutch-fork-return-spring-91377.html http://legacygt.com/forums/showthread.php/noise-typicali-177666.html http://legacygt.com/forums/showthread.php/slave-cylinder-clutch-fork-iiiii-154524.html http://legacygt.com/forums/showthread.php/crickets-chirping-clutch-pedal-released-154094.html http://legacygt.com/forums/showthread.php/throw-out-bearing-chirping-30-miles-after-brand-new-installi-209105.html?t=209105 Link to comment Share on other sites More sharing options...
chamorudude87 Posted November 15, 2013 Author Share Posted November 15, 2013 Thank all good advice, I've done everything except installing return spring...looks like I got something to do today . Sent from my SM-N900T using Tapatalk Link to comment Share on other sites More sharing options...
