IceCold81 Posted November 1, 2013 Author Share Posted November 1, 2013 Sounds good, and yea def don't wanna do that... I'm usually SUPER careful about initial threading... Cross threading sucks Link to comment Share on other sites More sharing options...
MAP Posted November 2, 2013 Share Posted November 2, 2013 Yes, be careful with the back bolt. Some time back I removed the pump to figure out where an oil leak was coming from. When I reinstalled the pump and went to tighten the rear bracket bolt, I discovered that it was stripped. I just left it as is. (the leak at the time was from the adapter that the oil pressure sensor sits in, it was loose) Link to comment Share on other sites More sharing options...
IceCold81 Posted November 2, 2013 Author Share Posted November 2, 2013 Do you think someone was in there before you toying around, and did that? Link to comment Share on other sites More sharing options...
MAP Posted November 2, 2013 Share Posted November 2, 2013 That's definitely what happened. I bought the car with 69k miles and hadn't touched that bolt before. I'm going to be replacing my pump tomorrow. I can't believe how dry the pump is in those pics in the previous posts. Mine is an oily mess. Link to comment Share on other sites More sharing options...
IceCold81 Posted November 2, 2013 Author Share Posted November 2, 2013 That's definitely what happened. I bought the car with 69k miles and hadn't touched that bolt before. I'm going to be replacing my pump tomorrow. I can't believe how dry the pump is in those pics in the previous posts. Mine is an oily mess. HA! SAME HERE MAN! My pump/area is just slop. Been bleeding for years Link to comment Share on other sites More sharing options...
FJuan Posted November 3, 2013 Share Posted November 3, 2013 I've had to replace my pump once before due to the bearings on the pulley leaking. Since then, I haven't had a problem since beside the o-ring on the inlet tube go out. Once I replace the o-ring everything was good to go. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
IceCold81 Posted November 3, 2013 Author Share Posted November 3, 2013 Yea mine besides of course oozing fluid everywhere, when it gets colder out, or making aggressive lock to lock turns while not moving, it would screech and shutter in the steering wheel, and you could watch the pump pulley stall/lock up for a moment and then start moving again... Would cause the belt screech. Been dickin with this since last year! haha... Slightly procrastinating, the summer it was better and more tolerable But it's getting colder and worse again. Time to replace for sure Link to comment Share on other sites More sharing options...
jersey LGT Posted November 3, 2013 Share Posted November 3, 2013 Power steering is over rated anyways. The ladies will love those Popeye forearms you'll develop from man handling the car while you parallel park. On a more serious note tho, now is the time to handle all that maintenance you've been putting off. The winter takes a good toll on everything. I did my timing belt, water pump, plugs, hoses like two weeks ago. If you love your car, you gotta maintain it. Link to comment Share on other sites More sharing options...
IceCold81 Posted November 7, 2013 Author Share Posted November 7, 2013 Power steering is over rated anyways. The ladies will love those Popeye forearms you'll develop from man handling the car while you parallel park. On a more serious note tho, now is the time to handle all that maintenance you've been putting off. The winter takes a good toll on everything. I did my timing belt, water pump, plugs, hoses like two weeks ago. If you love your car, you gotta maintain it. Well funny you say that, considering I just dropped about $1,600 this last week on the sooby! Ugh.... Bank account hates me, BUT.... I'm at 104k and I have officially completed the following services: Timing BeltTensionerWater pumpFront/rear differential fluid change/refreshCoolant system flushTrans FlushOil ChangeNew IntercoolerNew PCV assembly (Putting in this weekend HOPEFULLY, as long as it isn't a dick when I'm trying to take it out)New Power steering pump (Also going in this weekend)Obviously power steering fluidTires rotated and rebalanced I think that about covers it for now ha! But she's DEFINITELY ready for winter! = LOVE CAR! Link to comment Share on other sites More sharing options...
MAP Posted November 7, 2013 Share Posted November 7, 2013 Considering our vehicles have similar mileage( mine is at 111k), it's not a coincidence that we're changing the same things out. I changed the PCV assembly this weekend as well as the power steering pump. That hose on the PCV assembly that connects to the large fitting on the block is rock hard. I recommend just slicing the side of the hose after you remove the clamp with a big f***n screwdriver and removing it that way rather than trying to pull it off. The PCV valve that I removed still rattled but not as well as the new one I put it. Link to comment Share on other sites More sharing options...
IceCold81 Posted November 7, 2013 Author Share Posted November 7, 2013 Considering our vehicles have similar mileage( mine is at 111k), it's not a coincidence that we're changing the same things out. I changed the PCV assembly this weekend as well as the power steering pump. That hose on the PCV assembly that connects to the large fitting on the block is rock hard. I recommend just slicing the side of the hose after you remove the clamp with a big f***n screwdriver and removing it that way rather than trying to pull it off. The PCV valve that I removed still rattled but not as well as the new one I put it. Yea absolutely, nice 100k+ maint we'll call it. And seriously, I'm a little concerned about this dang PCV valve man... I had the intercooler off and gave it a quick shot and quickly gave up 2 weeks ago after realizing it was NOT going to be as easy as I thought to get out... What did you do when removing yours? Did you remove the breather line on the back of the intake to give yourself more room to operate? Method of putting the new one back on? I'm really not looking forward to tackling this thing, it's freaking BURIED in there, not sure how the clips are going to work out either Link to comment Share on other sites More sharing options...
MAP Posted November 7, 2013 Share Posted November 7, 2013 As soon as you pull off the intercooler the main body of the PCV sits below. Two hoses branch off. One toward the drivers side under the intake manifold. That is a simple clamp that you can remove with needle nose pliers. The other side of the assembly, plastic portion with O-ring that looks like a connector plugs in under the manifold on the passenger side. You just push on a clip that locks it in place and pull to disconnect. For the main assembly, there is a ~1 inch diameter hose that's about 3 inches long or so. It is secured to the block with a clamp and also at PCV valve assembly with another clamp. I used a screwdriver to pop off the top clamp..just pried the screwdriver between hose and clamp and tapped it with a hammer a couple times. Then you can pull off the main PCV valve assembly and only the ~1inch diam. hose remains. On that hose use the same procedure to remove the bottom clamp. Then slit the side of the hose near the block with a knife. Mine was so hard that it just split open and I just pulled it off. The trickiest part was using a wormgear type clamp at the bottom of the hose to attach the new assembly. I had to use an extension and u-joint fitting to tighten the screw on the clamp from the driver's side. Not fun, but was able to do it. While I was there, I also used plastic cable tie wraps on the exposed vacuum hoses that attach to the blue t-fitting since they were easily accessible. If you do this beware the hose from one of the fittings that plugs into the intake manifold. I found out after I put everything together that I had a vacuum leak. After I removed the intercooler again I realized that I ended up pulling off the hose mentioned previously from the manifold fitting. Link to comment Share on other sites More sharing options...
MAP Posted November 7, 2013 Share Posted November 7, 2013 I also removed the connector for the knock sensor since it was getting in the way. Link to comment Share on other sites More sharing options...
IceCold81 Posted November 7, 2013 Author Share Posted November 7, 2013 I also removed the connector for the knock sensor since it was getting in the way. Not sure I follow on this one? Appreciate the feedback man! Link to comment Share on other sites More sharing options...
jersey LGT Posted November 21, 2013 Share Posted November 21, 2013 How'd you ever make out with all the work? Link to comment Share on other sites More sharing options...
Pazuzu Posted November 21, 2013 Share Posted November 21, 2013 Just did my pcv it was a pita for sure. Patience is your friend here. Link to comment Share on other sites More sharing options...
Turkeylord Posted November 21, 2013 Share Posted November 21, 2013 When I did my PCV, I put a ratchet wrench on the worm clamp screw and put a couple wraps of electrical tape around the whole thing. Kept the wrench firmly on the clamp till it was tight, then I just twisted it out the tape. Link to comment Share on other sites More sharing options...
IceCold81 Posted November 22, 2013 Author Share Posted November 22, 2013 How'd you ever make out with all the work? Well at this point pretty close. Timing Belt - Done Tensioner - Done Water pump - Done Front/rear differential fluid change/refresh - Done Coolant system flush - Done Trans Flush - Done Oil Change - Done New Intercooler - Done New PCV assembly (Putting in this weekend HOPEFULLY, as long as it isn't a dick when I'm trying to take it out) - Revisiting when I feel like I'm in a SUPER patient mood, part going back on the shelf ha New Power steering pump (Also going in this weekend) - Didn't go on ha... Pending Obviously power steering fluid Tires rotated and rebalanced - Done - Still rides like shit with a vibration around 70 Link to comment Share on other sites More sharing options...
