101 Posted October 29, 2013 Share Posted October 29, 2013 My '07 Legacy 2.5i w/only 72,000 miles recently seized up, with no warning except for rod knock, which started three minutes before it seized. My question is this: does anyone know a good shop in Vegas who will not overcharge and do good work? Subaru dealer wants 1700 to diagnose, which means tear down, plus 5000-8000 for repairs. Told me has to remove the engine and trans together and that the torque converter may have been damaged because the engine seized. If torque converter is damaged, then add 1500. Oh, and I changed my oil every 3000 miles, frequently checked, so can't figure out why the engine would seize. Maybe it knew I was 8 months out of warranty... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 29, 2013 Share Posted October 29, 2013 $5K-$8K to fix it?? tell them F&%K NO! you can buy a used moderate mileage 2.5i for that! Now that ive spat all over my laptop, the trq converter should not have been affected by the seize and resulting stall. Since it knocked then seized up I would abandon that engine use it as a core towards a rebuilt long block. I say a long block over a shortblock b/c the cost to swap the heads and time it with the new shortblock will be more depending on the price of the longblock/or shortblock. Even with regular changes oil has to be checked constantly with these engines do you change it or have it changed at a quick lube/shop? Not sure about repair prices in LV area but I would NOT go to that dealer that is outrageous and a slap in the face to quote you a price that is more than your car is worth. YOu should be looking to have the engine pulled and: rebuilt (if the price is right) or replaced with a rebuilt EJ253. Not sure of your vehicle situation but I would not spend $5K to fix this car or if you do plan to keep it forever. Link to comment Share on other sites More sharing options...
101 Posted October 29, 2013 Author Share Posted October 29, 2013 I changed the oil myself and had the dealer change it a few times as well. Never a quick-lube place. Recently had headgaskets installed, then one side started leaking and dealer (not in Las Vegas) fixed that again about 6 months ago. I believe they screwed something up but no way to prove it. Kept all my records, Subaru offering only 1500 dollars good-will. I agree, the dealership is way too expensive. Thanks for your advice! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 30, 2013 Share Posted October 30, 2013 I changed the oil myself and had the dealer change it a few times as well. Never a quick-lube place. Recently had headgaskets installed, then one side started leaking and dealer (not in Las Vegas) fixed that again about 6 months ago. I believe they screwed something up but no way to prove it. Kept all my records, Subaru offering only 1500 dollars good-will. I agree, the dealership is way too expensive. Thanks for your advice! Wow $1500 good will those bastards! If you have had head work done i would find those records and contact Subaru of America (SOA) if it was starved of oil and they can prove it then the $1500 goodwill is at least something but if somethings happened as a result of fault work it could help you out greatly down the stretch. Link to comment Share on other sites More sharing options...
Jay12Legacy Posted November 1, 2013 Share Posted November 1, 2013 You sure something did break in timing belt area and the engine is free spinning? Jay Link to comment Share on other sites More sharing options...
Fast Eddie Posted November 1, 2013 Share Posted November 1, 2013 Take the cylinder heads off and see if it's really locked. Or easy way take the timing belt off, spark plugs out. and rocker arms off and see if she turns. Link to comment Share on other sites More sharing options...
FJuan Posted November 1, 2013 Share Posted November 1, 2013 As mention, pull the timing belt cover off and inspect the timing belt and pulleys first. If the timing belt came off or broke, you'll just to replace the valves in the heads. Otherwise, if you through a rod or spun a bearing, it's a lot cheaper to buy a rebuilt shortblock or find a good maching shop to rebuilt it for you. You can find rebuilt shortblocks for under $2k. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
101 Posted November 1, 2013 Author Share Posted November 1, 2013 Thanks for the help! I checked the timing belt and it's not broken. I'll try all the suggestions to see if I can get it to turn. Subaru dealer said they tried to rotate the engine but it's seized tight and they could not get it to move. Removing the belts and spark plugs may help, though. I told SOA about the twice replaced head gaskets, gave them the records and still they would only give 1500 dollars towards repair. Link to comment Share on other sites More sharing options...
Brian3676 Posted November 2, 2013 Share Posted November 2, 2013 A entire new short block is $1800-1900 plus say the heads need compleat re doing at 300-500 each, that's 3k. Labor, gaskets, misc supplies. 2k. Then assume they are quoting new timing belt kit, maybe an oil pump. There is between 5-6k. Link to comment Share on other sites More sharing options...
