Kingfisher Posted August 19, 2005 Share Posted August 19, 2005 I was just cruising around in my wife's new '05 LGT and notice that there's a blue wire, or rather blue wrapped wire(s) coming out from under the console going down under the seat somewhere (didn't bother to look real close). Is this a feature, or did someone forget to run the wire underneat the carpet? Link to comment Share on other sites More sharing options...
melayout Posted August 19, 2005 Share Posted August 19, 2005 It's the Subwoofer wire. There is a Technical Service Bulletin(Attached) out and your dealer should know about it and reroute the wire. MojoSub-woofer Wiring Harness Re-routing.pdfSub-woofer Wiring Harness Re-routing.pdf I keed I keeed Link to comment Share on other sites More sharing options...
Kingfisher Posted August 19, 2005 Author Share Posted August 19, 2005 Excellent, I figured as much. From what I can tell this is an early build '05, which is probably why it has this particular "feature". Thanks for the PDF on the TSB. I'll get the yayhoos at the dealer to take care of it. Link to comment Share on other sites More sharing options...
jasonetc Posted August 19, 2005 Share Posted August 19, 2005 where is the sub? Link to comment Share on other sites More sharing options...
jagcars26 Posted August 19, 2005 Share Posted August 19, 2005 In my car it's under the drivers seat. Rudy Link to comment Share on other sites More sharing options...
Kingfisher Posted August 19, 2005 Author Share Posted August 19, 2005 Correct. That's where it is. Link to comment Share on other sites More sharing options...
VXCL Posted August 19, 2005 Share Posted August 19, 2005 wait so you got a lgt without the sub but all the wires are ran already? i wish mine was like that. then i might get the sub for the meantime, but i dont feel like taking the dash apart for it. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
axis008 Posted August 20, 2005 Share Posted August 20, 2005 Moved to "interiors" section. -ben Link to comment Share on other sites More sharing options...
