Causes of melted O2 sensor?
Pic added!
I've been looking for a vac leak for quite sometime to no avail on my 07 LGT< about 70k miles. I thought I had it ironed out, but getting an etune as soon as I pulled a LV the fuel trim was sky high. Back to searching for a leak. Got fed up, took to the dealership. They called to say an O2 sensor had it's tip melted, which was confirmed by the sales guy I know texting me to let me know that thing is fried.
Besides being plowed by the cost (and didn't even buy me dinner first) I am just wondering of the potential cause of this? I want to make sure to do what I can to prevent in the future. Clogged/failing cat? Just too much awesome pumping through the exhaust? :)
Overheating an O2 sensor is "interesting". Not impossible, but I can think of a few possible causes:
  • Bad Exhaust Gas Temperature (EGT) sensor - if it isn't working it doesn't detect a high temp condition and therefore appropriate action isn't taken by the ECU (richer fuel mixture etc.)
  • A changed exhaust or intake without a tune.
  • Injectors in need of maintenance.
  • An air leak somewhere in the system (both intake manifold and exhaust)
  • O2 sensor itself has been reporting the wrong value causing a loopback problem to escalate.
  • Bad valve. (Check compression and valve clearances)
And the cat may also take a beating if this has happened.
Hmmm ok thanks for the info.
Prob not the cat since I just pass a smog a few months back.
My MPG did drop over the past 6 - 8 months, so it seems the O2 sensor was slowly going out. Still no CEL up to this point as well.
Once I get the car back I'll take it for a drive and pull some logs to see if there are any changes.
All stock, no mods of any kind. So exhaust/intake are out.
Vac leak - possible. Though I've gone over everything and can't find one, will have to check trim level and see if there is an issue.
Any way to test the EGT?
Injectors/valves/compression I'll have to get checked.
How bad wasthe cost of the O2 sensor ? I gather it was the front one.
I just replaced the front O2 on my wagon with a OEM one. It was like $130 with tax after my discount. I think retail is like $160.
Engine Build - Click Here
I'm guessing if the MAF is bad and sending bad info to the ECU, that could cause issues.
I'm surprised you didn't get a CEL.
Hey, at least the car is fixed and you can enjoy driving it.
Spending a ton of money on these cars seems to part of the norm now.
Cars been owned free and clear for well over a year now and I haven't spent much $$$ on this car so far, since I've done most everything myself. So it balances out. Fingers crossed the MAF and O2 clear up my fuel trims and I can get my Cryo tune going. Have already held Dave up for too long on this and I'm sure he is getting tired of my email updates. :)
Good Luck. :)
I'm about to spend more money on my wagon soon. Like a idiot I went and opened the GB forum. What do I see... Mike has a GB for sway bars....damn him.... :)
Good Luck. :)
Great. I both love and hate the fact that you pointed this GB out. Sway bars are on my list for the future, but I'll probably kick myself if I miss out on this.
My wallet is displeased (but it'll get over it).
