Anil_Trinidad Posted October 7, 2013 Share Posted October 7, 2013 Hello all. I am new to this forum - and have had a look at some of the wheel fitment threads. However, I have a question regarding the use of 235/40/18 tires on a set of 18x8 +35mm, then taking the same tires and putting them on a set of wheels that are 18x8.5, +48mm. Stock suspension on '08 JDM Legacy 2.0T (that came with 17's). My cousin has a set of white Konig Lightnings (which are 18x8 +35mm) that came off his '06 Fozz - that I intend to use until I get a set of Enkei PF01's that are 18x8.5, +48mm. So I'm checking to see if I can use the same tires on both sets of wheels without any issues. I suspect that the 35mm offset will sit more outside of the fender, but with stock ride height - I am hoping to have no rubbing - but since I'm not sure, I am asking the question. My preference is to use 235 instead of 225 width tires. Any ideas? Link to comment Share on other sites More sharing options...
.Catalyst. Posted October 7, 2013 Share Posted October 7, 2013 Should be fine at stock ride height. The wheels will poke more, but a 235 on a 8" wide wheel is no issue at all. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
