jayjay Posted September 25, 2013 Share Posted September 25, 2013 Will 2002-2007 wrx rear trailing arms, lateral links and endlinks fit my 98 lgt wagon? I apologize if this is answered somewhere, but i came across someone parting all whiteline suspension parts for dirt cheap! any help with whether these parts will fit is greatly appreciated. Link to comment Share on other sites More sharing options...
Zues Marine Posted September 25, 2013 Share Posted September 25, 2013 the endlinks will fit, trailing arms and laterals will not, SF foresters and the GC/GD model imprezas' stuff will for example Link to comment Share on other sites More sharing options...
bjkroll Posted September 25, 2013 Share Posted September 25, 2013 Ugh, I just did this. Ended up in the ER with steel in my eye after cutting the inside camber bolt out of the lateral arm. Should have worn goggles, not glasses. Best of luck! Link to comment Share on other sites More sharing options...
jayjay Posted September 26, 2013 Author Share Posted September 26, 2013 the endlinks will fit, trailing arms and laterals will not, SF foresters and the GC/GD model imprezas' stuff will for example thanks for the info, sucks im going to miss out on this deal. After looking at that link you provided, it claims laterals will fit, im confused now Ugh, I just did this. Ended up in the ER with steel in my eye after cutting the inside camber bolt out of the lateral arm. Should have worn goggles, not glasses. Best of luck! sorry to hear about your ordeal, which lateral arms did you try to put on. Link to comment Share on other sites More sharing options...
Zues Marine Posted September 26, 2013 Share Posted September 26, 2013 ive heard using both from a wrx may cause the axle to become too short, there was a thread somewhere all about it Link to comment Share on other sites More sharing options...
jayjay Posted September 26, 2013 Author Share Posted September 26, 2013 ive heard using both from a wrx may cause the axle to become too short, there was a thread somewhere all about it ok thanks, i guess ill just save up a little more to get laterals and trailing arms made specifically for my lgt instead of chancing it with the wrx parts! would the fact the the lateral arms are adjustable make a difference? Link to comment Share on other sites More sharing options...
