datdookie Posted September 24, 2013 Share Posted September 24, 2013 Hello, so Im doing a head head job for my ej22e and I bought all new parts or so I thought so. Dude at the machine shop said I needed "valve spring shims". What are they and do the ej22e havw them. Searched google but really didn't come up with anything. Peter Link to comment Share on other sites More sharing options...
Zues Marine Posted September 24, 2013 Share Posted September 24, 2013 here's a good online parts catalog: http://opposedforces.com/parts/legacy/ Link to comment Share on other sites More sharing options...
pleaidestar Posted September 25, 2013 Share Posted September 25, 2013 ^broken link? Link to comment Share on other sites More sharing options...
datdookie Posted September 25, 2013 Author Share Posted September 25, 2013 http://www.rs25.com/forums/f5/t103391-valve-spring-question.html I think I know what the machinest was talking about. Well at least according to this thread The valve spring seats!! But I'm still having trouble finding the part number. That site was pretty difficult to use and when I dis find the right page the actual part that was was in the diagram was number 2 but dis not list the part number for it. So by any chance does anyone know the part number for a ej22e (95 legacy) Link to comment Share on other sites More sharing options...
Zues Marine Posted September 25, 2013 Share Posted September 25, 2013 ^broken link? nah, it works for me Link to comment Share on other sites More sharing options...
datdookie Posted September 25, 2013 Author Share Posted September 25, 2013 So I'm still stuck. I think the ej22e does not come with valve springs seats. By looknow ng at the OEM catalogs of other subies like the wrx's compared to my car, they have an actual slot that says " valve spring seat" So I m assuming the springs sits right on the head itself, which I don't think is good. Baah Peter Link to comment Share on other sites More sharing options...
snederhiser Posted September 25, 2013 Share Posted September 25, 2013 Hello; Were you going to simply lap-in the valves or do a real valve grind job? Remember that you are working with a non-ajustable lifters here. I use a dial indicator that measures the stem length from the spring seat. When you grind the valve and valve seat, the stem sticks up further needing to be ground off! Thus a spring spacer needs to be used to lift the spring up to maintain the proper tension. I would think Napa or Goodson would sell these, Steven. Link to comment Share on other sites More sharing options...
datdookie Posted September 25, 2013 Author Share Posted September 25, 2013 Snederhiser, thanks for the reply and to answer your question the valve has been grinded and seated...I guessed I f'd up on that one unless I can find these spring spacers your talking about. You know what height or thickness should be if I got 3 angle valve job? Thanks Peter Link to comment Share on other sites More sharing options...
sbw Posted September 25, 2013 Share Posted September 25, 2013 you could take some length off the valve stem instead of going with a different shim but if the clearance is already too big you're gonna need larger shims. Most machine shops will move shims around to make it so you have to buy the least amount of shims possible. They're in there. You're machinist should've told you what thickness shims you need. Link to comment Share on other sites More sharing options...
datdookie Posted September 27, 2013 Author Share Posted September 27, 2013 Thanks for all giving your .02 cents, machinest went out and got the shims he needed. Peter Link to comment Share on other sites More sharing options...
