IGW Posted September 26, 2013 Share Posted September 26, 2013 O I'm the same way...mostly been with airride on trucks. I bought a 1999 mazda brand new and within 30 built a new chassis from the firewall back out of 2×3×3/16 tubing. I have the "itch". If I'm fine on the stock map then I'm going to leave well enuff alone untill I fell the need to go faster. Lately I have been going below the speed limit on the interstate to see how good my gas mileage can be. A friend of mine has an aftermarket uppipe, could I install that without a tune? Link to comment Share on other sites More sharing options...
m sprank Posted September 26, 2013 Share Posted September 26, 2013 Yes. You will need a resistor to "trick" the ecm when you remove the EGT sensor. A tune will gain mpg at cruise. You can adjust the ACVS for slightly better mpg. Link to comment Share on other sites More sharing options...
IGW Posted September 26, 2013 Share Posted September 26, 2013 Dose the resistor plug into where the sensor once did Link to comment Share on other sites More sharing options...
m sprank Posted September 26, 2013 Share Posted September 26, 2013 Yes. Just cross the terminals with the resistor. 2.2kohm 5 watt. http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-2k-5w-resistor-up-pipe-131488.html for reference. Link to comment Share on other sites More sharing options...
IGW Posted September 26, 2013 Share Posted September 26, 2013 Thank you very much for taking the time to answer my questions. Will the stage 1 tune from a accessport help me increase mpg? Link to comment Share on other sites More sharing options...
m sprank Posted September 26, 2013 Share Posted September 26, 2013 It should. But once again, most customers dont realize the savings because they are using more right foot. Link to comment Share on other sites More sharing options...
IGW Posted September 26, 2013 Share Posted September 26, 2013 Understandable Link to comment Share on other sites More sharing options...
Max Capacity Posted September 26, 2013 Share Posted September 26, 2013 Thank you very much for taking the time to answer my questions. Will the stage 1 tune from a accessport help me increase mpg? Stage 1, yes, even a good stage 2 like my wagon has from TA (mike kinsman), it get's better mpg then it did stock. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
