phesa1005 Posted September 11, 2013 Share Posted September 11, 2013 I decided to take a look at my intercooler today. And I was wondering if this was normal. Link to comment Share on other sites More sharing options...
chato Posted September 11, 2013 Share Posted September 11, 2013 no. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 12, 2013 Share Posted September 12, 2013 Time to BP your TMIC. see http://legacygt.com/forums/showpost.php?p=4520400&postcount=528 and main thread here: http://legacygt.com/forums/showthread.php/bullet-proof-tmic-kits-189608.html Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2013 Share Posted September 13, 2013 It looks like just oil film to me. I think the tabs all look good. Did you clean it off ? A little oil film is normal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Bbc84 Posted September 16, 2013 Share Posted September 16, 2013 mine was wet like that on my wagon. I cleaned the top mount inside with some gasoline and it was just dripping out of the corners of the end tanks. I re crimped the tabs as best as i could and then JB weld all the tabs to the end tank. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted September 16, 2013 Share Posted September 16, 2013 Doesn't seem too bad, maybe good to replace the PCV valve. It's common for our cars to see some oil in the intake areas, lots of oil is a problem though. Do you use much oil between your oil changes? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
phesa1005 Posted September 16, 2013 Author Share Posted September 16, 2013 Only 5 qts of oil. And thanks guys ill check out the PVC Link to comment Share on other sites More sharing options...
ehsnils Posted September 16, 2013 Share Posted September 16, 2013 Is it a crack that I see in the red circle? Otherwise it just looks dirty. Link to comment Share on other sites More sharing options...
