gcallahan Posted September 9, 2013 Share Posted September 9, 2013 06 LGT sedan 75xxx miles. Last week helping a friend move and all of a sudden I get this loud banging sound from my right front. I pull over, check the lug nuts, all tight. When I get the car home, jack up the front pull the wheel and look for anything loose. Nothing. Get a pry bar and start checking for play in the ball joint, the coil mounts the strut itself. Nothing. Then I pry on the rear of the lca where it mounts to the body. The bushing is obviously bad. So I pull both lca's replace front and rear bushings on them and the ball joints while I have them off. Put it all back together and the banging is still there. It only happens when the right front tire goes over some uneven patches in the road. I have looked all over the right front of the car and everything is tight. I am stumped, any ideas. Thanks G Link to comment Share on other sites More sharing options...
GTEASER Posted September 9, 2013 Share Posted September 9, 2013 blown shock? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 13, 2013 Share Posted September 13, 2013 blown shock? ^^^Could be this or possibly a broken sway bar inside of the bushing. I've seen sway bars break inside of the bushing and they still look normal. Link to comment Share on other sites More sharing options...
EJ25subie05 Posted September 13, 2013 Share Posted September 13, 2013 or an endlink, my is300 had a horrible clunk with a bad end link. op did you check for play by grabbing wheel at 12 and 6 and pushing in and out for bearing play and such and up and down to check for shock bushing play? etc. Link to comment Share on other sites More sharing options...
gcallahan Posted September 13, 2013 Author Share Posted September 13, 2013 Thanks for the input guys. The shock or strut looks fine. No oily residue on any of it. The suspension is working properly through its cycle. Ride height is the same. When re installing the lca's, several times I had to move the sway bar to clear one or the other lca, and it also looks fine. The end links are aftermarket with good bushings. The only thing I see is the inner cv boot is torn. But the joint has minimal play. It really feels and sounds like the upper strut mount is loose. But I have check it several times and its tight. I'm stumped. Link to comment Share on other sites More sharing options...
GTEASER Posted September 13, 2013 Share Posted September 13, 2013 Also check the shock to tophat bolt. If that loosens it can clunk. I wonder if the steering bearing between the upper spring perch and tophat has gone out. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
gcallahan Posted September 14, 2013 Author Share Posted September 14, 2013 GTEASER, I have done a little more research and I think your right with the steering bearing. So yea... I get to tear her back apart. Thanks G Link to comment Share on other sites More sharing options...
gcallahan Posted September 28, 2013 Author Share Posted September 28, 2013 GTEASER. Yep it was the shock to tophat bolt. Thanks G Link to comment Share on other sites More sharing options...
