nnblackgt Posted September 7, 2013 Share Posted September 7, 2013 My legacy gt started knocking when it first turns on at idle but its not constant sounds like its coming from the back but not sure. check engine light is on and cruise light is flashing. pulled up codes P0021 and P0113. i did an oil change nothing, changed maf sensor nothing, changed a ripped up alt, ps belt nothing. I believe those codes are camshaft sensor timing advanced and maf is bad. but not sure what to do now. Link to comment Share on other sites More sharing options...
ttnio Posted September 7, 2013 Share Posted September 7, 2013 It took about 50 miles before my P0011 code clear. Of course, I did the oil change. Link to comment Share on other sites More sharing options...
nnblackgt Posted September 8, 2013 Author Share Posted September 8, 2013 Have some good news just the main crank pulley is bad/loose or something i know i heard knocking that was irregular that didnt sound like engine knock it is wobbling front to back hitting the block going to see whats wrong. might be a good time to upgrade to a udp Link to comment Share on other sites More sharing options...
Max Capacity Posted September 9, 2013 Share Posted September 9, 2013 crank pulley is easy to replace. Good Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 9, 2013 Share Posted September 9, 2013 I just got this light combo after starting the car without pluging maf back in. Hope it clears itself as did the other guys. Sent from my S3 BNR18g on 93oct Link to comment Share on other sites More sharing options...
