4pasnu Posted September 4, 2013 Share Posted September 4, 2013 Looked everywhere and dealership and tech is useless. There is a seal where the 90 degree union fitting goes into the radiator for the transmission fluid. Anyone know the part number for the seal or a replacement someone has used? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 4, 2013 Moderators Share Posted September 4, 2013 not sure exactly what you're talking about, but do either of these help? http://opposedforces.com/parts/legacy/us_b13/type_6/cooling_system/engine_cooling/illustration_2/ http://opposedforces.com/parts/legacy/us_b13/type_6/cooling_system/engine_cooling/illustration_1/ "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
4pasnu Posted September 4, 2013 Author Share Posted September 4, 2013 yes, on illustration #2 where hose #16 goes into the radiator. There is a 90 degree brass union that screws into the radiator and that attaches to the #16 hose with a hose clamp. The double threaded coupler screws into radiator, there is a flat washer and a metal washer/ rubber seal. The seal has seperated from the washer and is leaking trans fluid. I can see and will not replace the whole radiator over a $5 seal/oring/gasket. Dealer had nothing on there screen and tech said there isnt one. Looked on a few at work and at dealer and they all have the flat washer and seal so it must or should be a replacement part Link to comment Share on other sites More sharing options...
quick4dr Posted September 5, 2013 Share Posted September 5, 2013 just add an aftermarket Hayden trans cooler plum the lines through there with a external thermostat and don't use the radiator for the trans. problem solved. then get a nice aluminum radiator and benefit from the the added cooling of that and your trans will be safe. just my .02 Link to comment Share on other sites More sharing options...
subiestang Posted September 6, 2013 Share Posted September 6, 2013 /\ thats what i did Link to comment Share on other sites More sharing options...
GEORGEROV Posted September 6, 2013 Share Posted September 6, 2013 Hi 4pasnu , Sounds like what you are describing is what we in Scotland call a " Dowty Washer " . A metal washer with a central elastomer ring . Any place that deals in hydraulic fittings should have them in various sizes . Link to comment Share on other sites More sharing options...
