dawkins20 Posted October 1, 2013 Author Share Posted October 1, 2013 Very true. It runs a lot of timing in cruise and mild acceleration, so in higher gears on highways there is quite a bit of low level knock. But I've been getting more intense timing pulls at mid loads (1.2-1.6) pulling -4 degrees or more and making the DAM drop. That was the trouble spot I had with the Cobb maps and an etune map also, so there is some fueling issue. Sometimes it is apparent as the logs show that the car is staying lean there and not following the map open loop fuel curve down fast enough, but other times I don't see a lean condition on the log. These log snippits were all from my drive home yesterday after testing the other MAF sensor. DAM drop x 2 Lean open loop knock DAM rise then drop And yet again Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted October 1, 2013 Share Posted October 1, 2013 Have you checked your cylinder roughness (per cylinder) misfire parameter, for each cylinder to make sure that looks normal? www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
dawkins20 Posted October 1, 2013 Author Share Posted October 1, 2013 Yeah. Nothing abnormal. No more that 1 counts intermittently in different cyls Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted October 1, 2013 Share Posted October 1, 2013 log your o2 voltage too. See if it's looking out of the ordinary. Might as well see if something comes out of the parameters available www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
dawkins20 Posted October 10, 2013 Author Share Posted October 10, 2013 So, repeated a smoke test, all buttoned up, no leaks. Also tested fuel pressure, 38psi at idle, rising to 47ish with the FPR line pulled, so those look good. I'm thinking injector maybe b/c otherwise I'm out of ideas Link to comment Share on other sites More sharing options...
