DevilHornz Posted August 31, 2013 Share Posted August 31, 2013 So I was driving home from work the other day and my a/c cut out 3 times,it still blew just not cold.....If I shut the system off and turned it back on it worked for a short while then cut out again..Has been ok since....leads me to believe it is a(was) electrical issue.....Has anyone else experienced this? Link to comment Share on other sites More sharing options...
CapSlo Posted September 3, 2013 Share Posted September 3, 2013 Low freon or compressor/clutch? Link to comment Share on other sites More sharing options...
DevilHornz Posted September 7, 2013 Author Share Posted September 7, 2013 Low freon or compressor/clutch? I am not sure on either one...it hasn't happened since everything is working just fine....I didn't stop to see if the compressor was not working while it was going on,and I haven't hooked up any gauges...but if the Freon was low it deffinatly would not be working more often.... Link to comment Share on other sites More sharing options...
cseagle08 Posted September 7, 2013 Share Posted September 7, 2013 Was it turning off after accelerating to high rpm? I think it turns off when at high rpm. At least mine does. Link to comment Share on other sites More sharing options...
DevilHornz Posted September 9, 2013 Author Share Posted September 9, 2013 Was it turning off after accelerating to high rpm? I think it turns off when at high rpm. At least mine does. No...I was city driving town speed limits at the time and wasn't getting on it at the time.... Link to comment Share on other sites More sharing options...
