xt2005bonbon Posted August 29, 2013 Share Posted August 29, 2013 As the title says, is it possible to have 'good' fuel trims (between -5 and +5 %) and still have a boost leak? Just wondering.. Link to comment Share on other sites More sharing options...
PtPixel Posted August 29, 2013 Share Posted August 29, 2013 It's possible, but not so common. The leak could only occur when under high boost, leaving the lower trims stable (seal being forced to leak under high pressures). You should see some trace of this in the high air flow rate (40+ g/s) though. Link to comment Share on other sites More sharing options...
