rje88 Posted August 23, 2013 Share Posted August 23, 2013 Was driving and stepped on the gas and trans downshifted (auto) and then all of sudden it acts like its in neutral. Any ideas? There is fluid in trans. 91 legacy non turbo automatic Thanks Link to comment Share on other sites More sharing options...
mnstrmech Posted August 24, 2013 Share Posted August 24, 2013 trans going bye-bye. aka. its failing Link to comment Share on other sites More sharing options...
rje88 Posted August 24, 2013 Author Share Posted August 24, 2013 trans going bye-bye. aka. its failing Is there any certain part of the trans that would cause this? If its something that needs rebuilding then I'm stuck with buying used auto trans...Or I'm thinking of trying to find a donor vehicle that is a 5 speed. Would you know by chance what's needed for a swap? I'm guessing trans, flywheel/pressure plate/clutch, shifter/pedal assembly, clutch master cylinder? Is the drive shaft different? Will my current front diff work with a manual? Link to comment Share on other sites More sharing options...
mnstrmech Posted August 24, 2013 Share Posted August 24, 2013 i cant answer any questions related to converting to a manual. Never done it. As far as the auto, usually a full rebuild is suggested anytime you have problems. Its a "while your there" thing. as in, while your there, might as well do it. Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 25, 2013 Share Posted August 25, 2013 Surrealmirage's auto to manual swap: http://www.surrealmirage.com/subaru/swap/swap.html He went all out but all the info you need is in there. Link to comment Share on other sites More sharing options...
rje88 Posted August 28, 2013 Author Share Posted August 28, 2013 Surrealmirage's auto to manual swap: http://www.surrealmirage.com/subaru/swap/swap.html He went all out but all the info you need is in there. Thanks for all your help. I'll let you know the outcome. I'm going to just swap in a used auto trans. There is no 5 speed 1st gen legacy's in my area. Link to comment Share on other sites More sharing options...
mnstrmech Posted August 28, 2013 Share Posted August 28, 2013 i recommened with any used trans drop the pan and throw in a fresh filter and i love the Valvoline Max-Life trans fluid. VERY good stuff. http://www.valvoline.com/products/brands/maxlife/automatic-transmission-fluid/37 A bit more than regular fluid price wise, but synthetic based. Good stuff. Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 28, 2013 Share Posted August 28, 2013 You probably know this but make sure the trans you swap in matches your rear diff. Link to comment Share on other sites More sharing options...
