m sprank Posted August 20, 2013 Share Posted August 20, 2013 http://www.infamousperformance.net/images/store_version1/storelogo/LOGO.jpg You read it right!!! Front Brembo BBK packages for the 05-12 LGT and 02-13 WRX with prices starting at $900 delivered!!! http://www.infamousperformance.net/media/00/a20791f12bcb76f7d8909d_m.jpg The "low down": We have 8 (as of 10/5/13) sets of Re-manufactured (rebuilt by Centric/Stop Tech) Subaru STI Brembo Front Calipers. The calipers come "loaded" with Centric Posi-Quiet pads. Calipers have been re-coated gold by Centric/Stop Tech. Logos are available (if you want to put them back on the calipers) from DocDesigns. Start with the "base" price. You choose the rotors and the stainless steel brake lines from the options listed. You can also choose to add different pads to the "kit" (options listed as well). We will supply the Motul RBF600 brake fluid to make sure you have everything you need to convert your front brakes to STi Brembos. All prices are delivered to the Con US (as part of the package). The options: All kits come with both Front left and Front Right "loaded" Brembo calipers and 1 bottle of Motul RBF600 brake fluid. "Base" price is $666 Choices in Rotors: Centric Premium Rotor 04 STi - Front= $162/pair DBA 02-13 Subaru WRX STi 10 Stud Hole Front Slotted Street Series Rotor = $220/pair DBA 04-13 Subaru STi 10 Stud Hole Front Slotted 4000 Series Rotor = $308/pair Stop Tech Power Slot 04 STi Front SportStop Slotted Rotor = $230/pair Stop Tech 04 STi Front Slotted & Drilled Sport Brake Rotor = $254/pair Choices in Lines: Techna-Fit Subaru Legacy GT Stainless Steel Brake Lines = $110 Stop Tech Subaru 05-09 LGT Front Stainless Steel Brake Lines = $70 Techna-Fit 02-07 WRX Stainless Steel Brake Lines = $85 Stop Tech 02-07 WRX Front Stainless Steel Brake Lines = $49 Stop Tech 08+ WRX Front Stainless Steel Brake Lines = $49 Techna-Fit 08+ WRX Stainless Steel Brake Lines = $85 Upgraded Pad Choices: Hawk Ceramic = $123 Hawk HPS = $120 Hawk HP+ = $125 Stop Tech = $74 Base kit plus Centric Premium Rotors and Stop Tech Lines is $898 delivered!!! Pix of calipers http://forums.nasioc.com/forums/attachment.php?attachmentid=71690&d=1377623471 http://forums.nasioc.com/forums/attachment.php?attachmentid=71691&d=1377623483 http://forums.nasioc.com/forums/attachment.php?attachmentid=71692&d=1377623492 http://forums.nasioc.com/forums/attachment.php?attachmentid=71693&d=1377623501 http://forums.nasioc.com/forums/attachment.php?attachmentid=71694&d=1377623510 Pic of the inventory waiting to ship http://forums.nasioc.com/forums/attachment.php?attachmentid=71695&d=1377623561 Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted August 20, 2013 Share Posted August 20, 2013 This won't last long... Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
m sprank Posted August 20, 2013 Author Share Posted August 20, 2013 Priced to sell, not sit on the shelf. There should be no doubt who has the lowest prices on Brembo BBK's. Get them while they are available. Link to comment Share on other sites More sharing options...
SpecBinNB Posted August 20, 2013 Share Posted August 20, 2013 Wish they would fit behind my stock 07 spec.B wheels. I use them for winters. Link to comment Share on other sites More sharing options...
angeltalin Posted August 20, 2013 Share Posted August 20, 2013 just waiting on my re-enlistment bonus and ill take a set StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
m sprank Posted August 22, 2013 Author Share Posted August 22, 2013 3 sets sold, 3 sets left. Link to comment Share on other sites More sharing options...
ama0787 Posted August 22, 2013 Share Posted August 22, 2013 so spec b 06-07 wheels will not work with the sti calipers? I thought front mounted with out changes and rear needed a special disk to and mounting bracket to work? What subaru wheels will work or o we have to use 18"?? TIA, Anthony Link to comment Share on other sites More sharing options...
m sprank Posted August 22, 2013 Author Share Posted August 22, 2013 so spec b 06-07 wheels will not work with the sti calipers? I thought front mounted with out changes and rear needed a special disk to and mounting bracket to work? What subaru wheels will work or o we have to use 18"?? TIA, Anthony Many 17" wheels will clear. But no LGT OEM wheels will. Link to comment Share on other sites More sharing options...
fstaslp Posted August 22, 2013 Share Posted August 22, 2013 How is the balance with these and rear LGT stock brakes? Link to comment Share on other sites More sharing options...
m sprank Posted August 22, 2013 Author Share Posted August 22, 2013 2 sets left. Link to comment Share on other sites More sharing options...
SBT Posted August 22, 2013 Share Posted August 22, 2013 Mike - glad you were able to pull this off. This is a great service. Thanks. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted August 23, 2013 Author Share Posted August 23, 2013 2 sets left. Very busy Friday bump. Link to comment Share on other sites More sharing options...
LegacyWGTW05 Posted August 24, 2013 Share Posted August 24, 2013 Do they fit stock rims? Link to comment Share on other sites More sharing options...
blongo804 Posted August 24, 2013 Share Posted August 24, 2013 No ^ Link to comment Share on other sites More sharing options...
m sprank Posted August 25, 2013 Author Share Posted August 25, 2013 Saturday bump. Have a great weekend! Link to comment Share on other sites More sharing options...
m sprank Posted August 26, 2013 Author Share Posted August 26, 2013 1 kit left. Link to comment Share on other sites More sharing options...
m sprank Posted August 27, 2013 Author Share Posted August 27, 2013 Pix of calipers http://forums.nasioc.com/forums/attachment.php?attachmentid=71690&d=1377623471 http://forums.nasioc.com/forums/attachment.php?attachmentid=71691&d=1377623483 http://forums.nasioc.com/forums/attachment.php?attachmentid=71692&d=1377623492 http://forums.nasioc.com/forums/attachment.php?attachmentid=71693&d=1377623501 http://forums.nasioc.com/forums/attachment.php?attachmentid=71694&d=1377623510 Pic of the inventory waiting to ship http://forums.nasioc.com/forums/attachment.php?attachmentid=71695&d=1377623561 Link to comment Share on other sites More sharing options...
SBT Posted August 27, 2013 Share Posted August 27, 2013 Linked photos aren't working and it was a fruitless effort to see the photos on Nasioc as well, even logged-in... - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted August 27, 2013 Author Share Posted August 27, 2013 I see them fine. Not sure what is up. Can anyone else comment on the ability to see the pix. Link to comment Share on other sites More sharing options...
GTEASER Posted August 27, 2013 Share Posted August 27, 2013 Nope, can't see 'em. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
blongo804 Posted August 27, 2013 Share Posted August 27, 2013 Can't see them. Weird. Link to comment Share on other sites More sharing options...
m sprank Posted August 27, 2013 Author Share Posted August 27, 2013 Re posting here so they can be seen. Attached Thumbnails http://legacygt.com/forums/attachment.php?attachmentid=161414&stc=1&thumb=1&d=1377645566 http://legacygt.com/forums/attachment.php?attachmentid=161415&stc=1&thumb=1&d=1377645566 http://legacygt.com/forums/attachment.php?attachmentid=161416&stc=1&thumb=1&d=1377645566 http://legacygt.com/forums/attachment.php?attachmentid=161417&stc=1&thumb=1&d=1377645566 http://legacygt.com/forums/attachment.php?attachmentid=161418&stc=1&thumb=1&d=1377645566 http://legacygt.com/forums/attachment.php?attachmentid=161419&stc=1&thumb=1&d=1377645566 Link to comment Share on other sites More sharing options...
blongo804 Posted August 27, 2013 Share Posted August 27, 2013 Ahh.. There they are. By the way M Sprank, I should mention a quicky from my experience with my Centric reman Brembo's so far.. The only problem I had, which can easily be fixed once I bring it to light here, is the little chrome seat plate thing that the pad sits on. Basically, one part of it was hanging over the edge (can't see this unless the pads are out) and it had to be grinded down. Otherwise, it was grinding into the back of my rotor. Sadly, I have no pics of any of this and I hope my description of "chrome seat plate thing" is clear enough as to what i'm trying to get at. Just wanted to throw that out there in case this happens to any of the customers you're selling sets to. This way you have an easier time diagnosing if they're slightly as unlucky as I was. Pretty weird problem, but it was a simple fix being that it takes 10 minutes to get these calipers back off lol. Link to comment Share on other sites More sharing options...
m sprank Posted August 28, 2013 Author Share Posted August 28, 2013 http://www.infamousperformance.net/images/store_version1/storelogo/LOGO.jpg Infamous Performance is proud to announce our new partnership with Delicious Tuning! http://www.delicioustuning.com/sites/default/files/styles/blog_image/public/delicious-tuning-%5Bicon%5D.pnghttp://www.delicioustuning.com/ Bill Knose of Delicious Tuning is now offering dyno tuning services at Infamous Performance using our Mustang AWD-150-SE dyno. About William is a second generation computer science engineer, after his mother an aerospace and mathematician and a second generation tuner after his father who calibrated jet engines, based on EPA guidelines for fuel economy and maximum thrust levels. William has attained a Bachelor’s degree from Saint Michaels College and graduated in 1999 with a major in Computer Science and a minor in Mathematics. In the time William graduated, he started tuning Subaru’s as one of the very first OEM custom Subaru tuners in North America. During his 13 years of tuning experience he has been involved in customizing the engine management systems in some of the most famous and well recognized vehicles of the past decade including the infamous Ken Block Gymkhana 1 and Gymkhana 2 race cars, Stephan Verdiers Formula Drift and Rally Cross race cars, Zenkai Motorsports Time Attack & Pikes Peak race cars, and of course the Crawford Performance’s Time Attack race car. His experience doesn’t stop there, he has also developed and received incredible feedback on his track tunes from the likes of Tanner Foust, Keiichi Tsuchiya and Tarzan Yamada, while applying that knowledge onto the tuned ECU’s of Dave Mirra, Travis Pastrana and Andre Lotterer (Two Time 24hr Lemans Winner). Beyond the race cars and drivers he has worked with, William has also tuned hundreds if not thousands of daily driven and track enthusiast vehicles over his career. Not only has he tuned vehicles in North America but remotely (via the internet) around the world. Background Delicious Tuning, Inc. roots date back to 1999 as a company providing high end engine management performance tuning, custom product and business development, and management support for new and developing companies in the aftermarket performance industry. William Knose is the owner and tuner at Delicious Tuning and his business background stems from I-Speed USA which was formed in 2001 as a company providing installation services, custom tuning, corporate internet presence, and they performed the first Subaru RS to WRX conversions in North America. I-Speed USA’s website and name were a well-recognized brand in the Subaru performance industry up through 2005 when it joined forces with a newcomer to the street performance world, Crawford Performance. With an agreement to focus on building the Crawford Performance brand, I-Speed USA was purchased by Crawford in 2008. The following year the infamous Ken Block Gymkhana 1 and Gymkhana 2 videos hit the performance industry by storm. Stunning, reliable, and powerful tunes wowed Ken Block and the industry allowing the Crawford brand to become the leader in the Subaru Performance tuning industry. Being in the right place at the right time, reliable and consistent engine builds, and precise engine management tuning made for an extremely successful Gymkhana 1 and Gymkhana 2 video. Resume of cars tuned Ken Block - Gymkhana 1 - EcuTeK Stephan Verdier - Formula Drift - EcuTeK Stephan Verdier - Pikes Peak - EcuTeK Stephan Verdier - Rally Cross - EcuTeK & Motec Ken Block - Gymkhana 2 - Motec Kevin Jones - Pikes Peak - EcuTeK Jimmy Keeney - Rally America - EcuTeK Jimmy Keeney - Rally Cross - EcuTeK Tanner Foust - Time Attack EcuTeK Ken Block - Gumball DC Shoes - EcuTeK Tarzan Yamada - 850HP Time Attack Subaru - EcuTeK Kevin Jones - La Carrera Champion - EcuTeK Kevin Jones - One Lap of America - EcuTeK Russ Warr - NASA Time Trials - EcuTeK Tarzan Yamada - Long Beach Super Lap Battle - EcuTeK Stephan Verdier - X-Games - EcuTeK & Motec Location Infamous Performance 1948 Don Lee Pl #8 92029 Escondido, CA United States Phone: (760) 781-1126 33° 7' 42.096" N, 117° 7' 11.0712" W See map: Google Maps www.infamousperformance.net Offering Delicious Tuning Scheduled Custom Dyno Weekday/Weekend Trips Custom E-Tuning with Dyno Verification EcuTeK Master Tuner - EcuTeK ProECU Cable Kits & Tuned Packages - Subaru BRZ, WRX, STI, FXT, LGT - Scion FRS - Nissan GTR Cobb Pro Tuner - Subaru WRX, STI, FXT, LGT UpRev Osiris Tuning - Nissan 350Z, 370Z PowerAxel Pro Tuning - 2010-2011 Hyundai Genesis 2.0T JEC Reflash Tuning - 1999-2002 Impreza 2.5 RS - 1999-2001 Impreza 2.2L - 1999-2002 Forester 2.5L Link to comment Share on other sites More sharing options...
m sprank Posted August 29, 2013 Author Share Posted August 29, 2013 BRZ/FR-S EcuTek tune is $595. WRX/STi/LGT/ForesterXT/OBXT AP (Access Port) or EcuTek tune is $695. Link to comment Share on other sites More sharing options...
