rbi estimator Posted August 19, 2013 Share Posted August 19, 2013 I have a "05" Legacy GT 2.5 Limited and while driving home not even a mile from work my car sputtered and then shut down. I checked all fluids and belts all good. Had car towed home and checked timing all good there also. With the timing being ok I tried to start it. The car turns over but I don't believe it is firing, I installed a new Crank Position Sensor hoping that would solve the issue but it didn't. Does anyone have any ideas it seems I have had this car in my garage more than on the road. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2013 Share Posted August 19, 2013 No Check engine light's ? Did you make sure the battery terminals were clean and tight ? How old is the battery ? Next would be fuel pressure ? Then do you have spark ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted August 19, 2013 Share Posted August 19, 2013 If there's no CEL and the car is cranking but not starting you can try with some starter fluid - if it picks up and dies then I would aim at a fuel system problem, probably fuel pump unless you actually have an empty tank. Link to comment Share on other sites More sharing options...
rbi estimator Posted August 22, 2013 Author Share Posted August 22, 2013 I have checked the battery and even tried starter fluid with no success, any other ideas welcoming all. Link to comment Share on other sites More sharing options...
heiche Posted August 22, 2013 Share Posted August 22, 2013 Can you try to pull codes? How did you check the timing? BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
urfsin Posted August 22, 2013 Share Posted August 22, 2013 I suspect you have a fuel issue based on what you said about the car sputtering. Slide It Sideways Link to comment Share on other sites More sharing options...
thisheregirafFe Posted August 22, 2013 Share Posted August 22, 2013 it ain't got no gas in it! i can put anything i want down here?! Link to comment Share on other sites More sharing options...
heiche Posted August 22, 2013 Share Posted August 22, 2013 He tried starter fluid, but no go BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
BoozeRS05 Posted August 22, 2013 Share Posted August 22, 2013 You have an built-in onboard CEL reader that will tell you the codes your getting. My guess without any CEL's its no gas or loose/corrosive battery cable. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
EJ25subie05 Posted August 22, 2013 Share Posted August 22, 2013 you either lost spark or fuel since it sputtered. check your fuel pressure, and your spark. then go from there Link to comment Share on other sites More sharing options...
thisheregirafFe Posted August 22, 2013 Share Posted August 22, 2013 bad fuel pump fuse?? i can put anything i want down here?! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2013 Share Posted August 23, 2013 Ok, let's start from the beginning, when you turn the key to on, do you hear the fuel pump prime ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted August 24, 2013 Share Posted August 24, 2013 I have checked the battery and even tried starter fluid with no success, any other ideas welcoming all. No ignition at all even though starter fluid makes me suspect the ignition then. At least it's good to start with that hypothesis and revise if needed. Since there are individual coils or at least one coil per two cylinders I would start with checking the incoming signals to the coils to see if there's voltage in the connectors on the low voltage side. If no voltage when ignition is turned on I would check fuse #12 in the fuse box by the hood opening handle in the drivers compartment (should be the ignition fuse). Check if there's voltage at both sides of the fuse. If not then I would suspect the ignition lock, even though it seems a bit unlikely since that would have caused other problems. The colored wires in the following pictures are what you shall look at to begin with. http://www.bedug.com/pics/Subaru/wiring-100.png http://www.bedug.com/pics/Subaru/wiring-101.png http://www.bedug.com/pics/Subaru/wiring-102.png Make sure that pin 2 has a good ground connection for each of the spark plugs, otherwise there's a risk of high voltage firing back into the ECU and toasting it. Red wire in the picture shall always have +12V when ignition is on, the green wires shall be pulled to ground and released to produce a spark. Adding a small test bulb (or LED with an inline resistor, but watch the polarity in that case) between pin 1 and 3 and cranking the engine shall create a pulsing light for each spark. http://www.bedug.com/pics/Subaru/wiring-103.png If there's voltage already at the coils but no spark is produced and no pulsing light when using a test bulb then I would suspect the ECU to be bad - or that there is an in signal to the ECU that is missing. Removing an ignition coil and inserting a spark plug into it and making sure it's grounded you should be able to see a spark in the spark plug gap. Just make sure to ground both spark plug and coil before test cranking to avoid high voltage tracing into the ECU. If there are sparks in the spark plug then I would go over to continue to suspect the fuel system, starting at the injectors to see if they have power through the Main Relay: http://www.bedug.com/pics/Subaru/wiring-107.png http://www.bedug.com/pics/Subaru/wiring-106.png http://www.bedug.com/pics/Subaru/wiring-104.png Here you check that there's 12V at pin 2 of each injector, and that there's a pulse when cranking between pin 1 and 2 of each injector. (a low wattage bulb or LED with a resistor shall work fine, same as for the ignition coils) http://www.bedug.com/pics/Subaru/wiring-105.png If you have pulses there as well, then it's time to look at the fuel pressure to make sure it is OK, since it may be the fuel pump that's bad - or you can simply be out of fuel. Another issue that can be suspected if both ignition coils and injectors has pulses is that the timing is off because the cambelt has jumped for some reason, but you should have a code for that, so I suggest that you get a code reader in order to capture problems not only now but also in the future. An continue with this thread if your hope is up: legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html?p=4487789#post4487789 Link to comment Share on other sites More sharing options...
rbi estimator Posted August 26, 2013 Author Share Posted August 26, 2013 Well I got her going and I truely appreciate all the input. The issue is my turbo again the oil seal has gone out in it and is blowing thru into the intake which has killed my plugs and who knows what else. This is the third one I have put on my car and each time it has been a factory defect which they have made good. But never the less having to put them on and then finding it has issues has gottin old. I have had a time with this so I need recommendations on where to purchase a good and trustworthy turbo or someone who I can send this one to and have it reconditioned, it has less than 300 miles on it. I bought this car for running back and forth to work about 60 miles round trip a day and it doesn't get run hard. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 26, 2013 Share Posted August 26, 2013 I got my vf52 from Mike at http://www.AZPinstalls.com ordered on Tuesday, had it on Wednesday. It's got over 31,000 miles and no shaft play. I also have both banjo filters removed. Something is killing your turbo's. fix that first. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ehsnils Posted August 27, 2013 Share Posted August 27, 2013 Well I got her going and I truely appreciate all the input. The issue is my turbo again the oil seal has gone out in it and is blowing thru into the intake which has killed my plugs and who knows what else. This is the third one I have put on my car and each time it has been a factory defect which they have made good. But never the less having to put them on and then finding it has issues has gottin old. I have had a time with this so I need recommendations on where to purchase a good and trustworthy turbo or someone who I can send this one to and have it reconditioned, it has less than 300 miles on it. I bought this car for running back and forth to work about 60 miles round trip a day and it doesn't get run hard. Check the oil pressure so it isn't too high - the pressure relief valve may be faulty. Link to comment Share on other sites More sharing options...
