carlson1984 Posted August 12, 2013 Share Posted August 12, 2013 I have a legacy gt, 05, this morning when leaving the house the car started feeling really weird when pushing gas pedal. Rpms will go up to 2500, down to 2k, up to 3000, down to 2500, etc while pushing constant on gas pedal, I've never felt anything like it, and no check engine light came on at all. recent maintains cue includes timing belt around 8k miles ago and haven't had any other problems since did this so am thinking not related, also really hoping can't have anything to do with turbo, which was also replaced around 20k miles ago. Really not even sure where to start on this one and tried to search with my vague explanation terms and not finding anything, any ideas?? Link to comment Share on other sites More sharing options...
rob-2 Posted August 12, 2013 Share Posted August 12, 2013 Auto or Manual? Link to comment Share on other sites More sharing options...
carlson1984 Posted August 12, 2013 Author Share Posted August 12, 2013 Sorry, automatic Link to comment Share on other sites More sharing options...
3pe Posted August 12, 2013 Share Posted August 12, 2013 Slipping clutches maybe, I'm not familiar with Subaru auto Trans but if the shift points are electrically controlled or vacuum controlled those could also cause the same issues. Have you checked the fluid, are there mods to the Trans. A possible clogged Trans filter will cause pressure spikes low fluid will cause heat slip Link to comment Share on other sites More sharing options...
carlson1984 Posted August 12, 2013 Author Share Posted August 12, 2013 Mods are Bnr 16g turbo when the turbo blew, which included infamous tune and oil line redirect kit to avoid that damn banjo bolt Link to comment Share on other sites More sharing options...
3pe Posted August 12, 2013 Share Posted August 12, 2013 Did you check the Trans fluid? Link to comment Share on other sites More sharing options...
carlson1984 Posted August 13, 2013 Author Share Posted August 13, 2013 Yes transmission fluid is fine, it is only doing this while accelerating, but very constant and repeatable... every time pressing on gas it is jerking for whole accelleration, think it could be just the fuel filter or something maybe??? Link to comment Share on other sites More sharing options...
3pe Posted August 13, 2013 Share Posted August 13, 2013 Of the car is knocking under load and pulling timing yes, but usually it picks up misfire cel when it does something like that. Does the car idle fine? Sad but it sounds more and more like Trans slip to me if the engine revs up without increasing speed while accelerating that is a tell tell sign of drivetrain slip. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 18, 2013 Share Posted August 18, 2013 Front O2 sensor. Check STFT and I'll bet it's reading -25 to +25. They go bad sometimes without setting a CEL and can cause the surging you're talking about. I just had it myself with an 8 month old NTK O2. If you know someone that has a good one, borrow it, throw it in, and I'll bet it clears up your problem. Link to comment Share on other sites More sharing options...
carlson1984 Posted August 19, 2013 Author Share Posted August 19, 2013 I picked up front 02 sensor, will be installing this week, hope this is the problem, Thanks! Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 22, 2013 Share Posted August 22, 2013 Did you get the O2 installed? Hoping it fixed your problem. Good luck with it. Link to comment Share on other sites More sharing options...
