dodgeboy3406 Posted August 12, 2013 Share Posted August 12, 2013 It's about time for an accessory belt change on my 2.5 Legacy. Rock Auto asked if I needed a belt "replacement tool"??? My first time but it looks like a pretty straight forward job. Belt covers, tension bolts and lock bolts..am I missing something??? Any help is appreciated. Thanx Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 12, 2013 Share Posted August 12, 2013 It's about time for an accessory belt change on my 2.5 Legacy. Rock Auto asked if I needed a belt "replacement tool"??? My first time but it looks like a pretty straight forward job. Belt covers, tension bolts and lock bolts..am I missing something??? Any help is appreciated. Thanx Some belts call for a stretch tool as the belts are stretch belts but for your legacy you are correct, loosen tension bolts, replace belts and reapply tension. As a good measure check the tension on belts after a few hundred miles and adjust if needed. Link to comment Share on other sites More sharing options...
dodgeboy3406 Posted August 12, 2013 Author Share Posted August 12, 2013 Some belts call for a stretch tool as the belts are stretch belts but for your legacy you are correct, loosen tension bolts, replace belts and reapply tension. As a good measure check the tension on belts after a few hundred miles and adjust if needed. Thanx for the confirmation GEE-OTTO belts on the way, no tool. Saturday afternoon wrench session scheduled in...... Link to comment Share on other sites More sharing options...
