Pittcrew Posted August 10, 2013 Share Posted August 10, 2013 my friend has 02/03 wrx mounts and he has some RS mounts would those fit my 98 legacy its a 2.5 Link to comment Share on other sites More sharing options...
Sludgeroo Posted August 10, 2013 Share Posted August 10, 2013 Either or should fit, seeing as you need to use a wrx cross member for a turbo swap in these chassis's. Link to comment Share on other sites More sharing options...
Pittcrew Posted August 10, 2013 Author Share Posted August 10, 2013 okay thanks cause my stock ones are starting to go. So they will work with my stock motor? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted August 10, 2013 Share Posted August 10, 2013 Yes, they'll work. You might need new nuts for the cross member bolts. I can't remember if pre MY99 is the same as MY99 and up. Link to comment Share on other sites More sharing options...
subikid90 Posted August 11, 2013 Share Posted August 11, 2013 They will fit -Subikid90Â 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Pittcrew Posted August 13, 2013 Author Share Posted August 13, 2013 ive been told that engine motor mounts are different so i mean motor mounts if that makes a difference. Link to comment Share on other sites More sharing options...
pleaidestar Posted August 13, 2013 Share Posted August 13, 2013 Doesn't, you have two motor mounts to the subframe and a pitch stop to the firewall..that's it for the motor side. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted August 13, 2013 Share Posted August 13, 2013 I installed Perrin STi mounts on my 96 LGT with a 99 short block.. No issues. They are not different at all. Link to comment Share on other sites More sharing options...
twisty Posted August 13, 2013 Share Posted August 13, 2013 are they stiffer? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted August 13, 2013 Share Posted August 13, 2013 Definitely. Link to comment Share on other sites More sharing options...
