13fido13 Posted August 10, 2013 Share Posted August 10, 2013 Sunroof doesn't go back and stop by itself anymore. Have to hold the switch back to make it go back. If I want it to go forward it goes forward 1-2" and then stop. I have to release the switch and push it again to make it continue forward. Sometimes if I move the sunroof back a bit and then back forward, the sunroof works as it should. The airbag system is in the same cluster, there are times the airbag light comes on and does not go off. A key switch cycle usually makes it go out again. Anyone had an issue with this? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 10, 2013 Share Posted August 10, 2013 Have you cleaned and greased the sunroof track ever ? Do you have the service manual, that may be some help ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
13fido13 Posted August 17, 2013 Author Share Posted August 17, 2013 Yeah. It's been lubed regularly. Anyone had one of those issues? Link to comment Share on other sites More sharing options...
Mechanic Posted August 29, 2013 Share Posted August 29, 2013 Where does one find a Subie service manual? Chilton and Haynes both suck. Link to comment Share on other sites More sharing options...
