legy outback Posted August 8, 2013 Share Posted August 8, 2013 My dad and i have downloaded the full factory service manual for my '98 legacy outback, and the valve cover looked different from what is in the manual, as did the brackets (what are those called?) that hold the cam shafts in place. Here's what they look like and this is what is in the manual, (for the '98 what year is this really?!?!? Link to comment Share on other sites More sharing options...
pleaidestar Posted August 8, 2013 Share Posted August 8, 2013 That illustrated picture is an ej22e. Definitely not what you have in the picture. You should have an ej25d, can look on the vin plate located on the left side strut tower, it will tell you a motor code. Link to comment Share on other sites More sharing options...
Zues Marine Posted August 8, 2013 Share Posted August 8, 2013 Or the stamp on the block Link to comment Share on other sites More sharing options...
legy outback Posted August 8, 2013 Author Share Posted August 8, 2013 the vin says it should have an ej25d..ill go take more pics and see if you guys can help? i have found no pictures what so ever with just the valve cover off to compare to Link to comment Share on other sites More sharing options...
legy outback Posted August 8, 2013 Author Share Posted August 8, 2013 the book we have also references a SOHC engine...did we really go that far wrong in getting a manual?! Link to comment Share on other sites More sharing options...
subikid90 Posted August 8, 2013 Share Posted August 8, 2013 You have an ej25d in the picture, and the fsm is showing the ej22e like pleaidestar said -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
legy outback Posted August 8, 2013 Author Share Posted August 8, 2013 thanks guys, dads been doing some digging of his own and we got the right manual!! thank you! Link to comment Share on other sites More sharing options...
