sunny5280 Posted August 4, 2013 Share Posted August 4, 2013 The defrost button for the climate control button is a little sticky. By this I mean when I select a different airflow with the remaining buttons the climate control button doesn't immediately pop up with typical click. It does pop back up and it doesn't take long but it's obviously sticking. I suspect the problem is due to soda running on to the controls when a cup is placed in the cup holders. So I'd like to take the climate control apart to clean it up. Has anyone done this before? I have removed this assembly when I replaced the lightbulbs but I don't recall if it was easy to gain access to underneath the buttons themselves. Due the button tops just pop off? Any advice on how to clean it without removal and disassembly? Link to comment Share on other sites More sharing options...
Zues Marine Posted August 4, 2013 Share Posted August 4, 2013 Whose DIY was written for this? Stang? I'll see if I can find the link Link to comment Share on other sites More sharing options...
sunny5280 Posted August 4, 2013 Author Share Posted August 4, 2013 Whose DIY was written for this? Stang? I'll see if I can find the link Thanks. I attempted to search this forum along with the Internet but I did not see anything dealing with this specific issue. If you have a link you could point me to that would be great! Link to comment Share on other sites More sharing options...
Stang70Fastback Posted August 4, 2013 Share Posted August 4, 2013 Indeed. T'was mine. Have fun! http://legacygt.com/forums/showpost.php?p=4212647&postcount=48 Link to comment Share on other sites More sharing options...
sunny5280 Posted August 5, 2013 Author Share Posted August 5, 2013 Indeed. T'was mine. Have fun! http://legacygt.com/forums/showpost.php?p=4212647&postcount=48 Thank you very much. This will be quite helpful. I saw your other post...perhaps the site should sticky this as a FAQ. Link to comment Share on other sites More sharing options...
Zues Marine Posted August 5, 2013 Share Posted August 5, 2013 Its already in a sticky :O Link to comment Share on other sites More sharing options...
sunny5280 Posted August 5, 2013 Author Share Posted August 5, 2013 Its already in a sticky :O Would that be the "2nd Generation (and possible others) DIY Guides" discussion? If so I'll know to look there next time (though I did do a search of this forum before posting so not sure how I missed it). Link to comment Share on other sites More sharing options...
Stang70Fastback Posted August 5, 2013 Share Posted August 5, 2013 Indeed it is Though that sticky is kind of a giant clusterfuck of DIYs with no real rhyme or reason, so I don't fully blame you... Link to comment Share on other sites More sharing options...
Zues Marine Posted August 5, 2013 Share Posted August 5, 2013 The search function on this forum is almost useless... Link to comment Share on other sites More sharing options...
