Aced Posted July 31, 2013 Share Posted July 31, 2013 So... I was thinking of R&Ring the timing belt on my Subie. Can someone recommend a good place to get a timing belt kit and a water-pump? I'm thinking it would probably be cheaper to order from the same website. The car was bought with unknown maintenance records...so yeah, I think it's time to take some precautionary measures. Also, just to make sure, is everything after '96 a Phase 2 motor and thus non-freewheeling? Thanks alot. Link to comment Share on other sites More sharing options...
Zues Marine Posted July 31, 2013 Share Posted July 31, 2013 i believe 98.5ish was the beginning of phase 2, early ej22s were non-interference... if that's what you mean Link to comment Share on other sites More sharing options...
Kennyfvholla Posted July 31, 2013 Share Posted July 31, 2013 Personally, I would only use an OEM timing belt on any of my cars. Same goes for the water pump and tensioner. And, as for your last question.. No. Any 2.5 from a Legacy from 96 to 99 have the same exact timing components. Link to comment Share on other sites More sharing options...
subikid90 Posted July 31, 2013 Share Posted July 31, 2013 Gates is all I use. Excellent quality parts. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
johnegg Posted July 31, 2013 Share Posted July 31, 2013 do a search of my posts for timing procedures. (in 3rd gen i think.) subaru is different than other engine makers. if you guess, you will get it wrong. lots of folks have on their first try. it isn't rocket science, but it is different. read first. you do want quality parts. but more important is to replace everything. replace the belt and everything it touches. (except the crank sprocket.) the belt rarely breaks. a pulley usually gives up, the bearing, because it was not change with the timing belt. i buy from ''theimportexperts'' on ebay. quality parts at a good price. you can buy cheaper parts, but not for the same quality. i have 45k on one of their kits and no worries. but buy what you want, just be sure to buy EVERYTHING. Link to comment Share on other sites More sharing options...
Aced Posted August 1, 2013 Author Share Posted August 1, 2013 Okay, I will buy EVERYTHING lol. Thanks. Link to comment Share on other sites More sharing options...
