ScoobyDoo94 Posted August 15, 2013 Author Share Posted August 15, 2013 Got the TGV sorted, but it still won't start. No codes. Engine kicks back when it dies and I don't know where to go next. Any ideas? Scratch that, P2005 code now... Link to comment Share on other sites More sharing options...
mwiener2 Posted August 16, 2013 Share Posted August 16, 2013 Timing is off My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted August 16, 2013 Author Share Posted August 16, 2013 It can't be, the engine was 100% in time when it got put in there's no way it could be off. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 16, 2013 Share Posted August 16, 2013 Your marks line up, but are they actually 180 off? Are the cam gears correctly installed on the cams? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted August 16, 2013 Author Share Posted August 16, 2013 They should be. There's only one way to put them on as far as I know. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 16, 2013 Share Posted August 16, 2013 Yeah, but did you put it on that way? You can bolt the cam on with it in the wrong position. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted August 16, 2013 Author Share Posted August 16, 2013 I did. The dial pin landed in the right spot on both intakes and the exhausts were on right too. Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted August 18, 2013 Author Share Posted August 18, 2013 Post above is wrong. My passenger side intake was NOT installed correctly. The pin was right beside the hole it was supposed to be in. With any luck I don't have any bent valves and the knock was pre-detonation, and not valve munching horror. It won't be until Thursday that I'll get the new sprocket (the hole that the alignment pin goes in got egg shaped and I don't feel comfortable using it.) Link to comment Share on other sites More sharing options...
mwiener2 Posted August 21, 2013 Share Posted August 21, 2013 Internet diagnosis FTW!!! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
