rob-2 Posted July 23, 2013 Share Posted July 23, 2013 I'm aware you look for around 140psi of compression without boost. Does anyone know about how much psi a cylinder is making with 16-17psi of boost in there? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 24, 2013 Moderators Share Posted July 24, 2013 I would guess the answer to this would be fairly complicated and would be subject to the increased volume of air being pushed into each cylinder under boost--way over my head. Why are you wondering this? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
RWebb Posted July 24, 2013 Share Posted July 24, 2013 Its not about PSI its about CFM. What turbo? Link to comment Share on other sites More sharing options...
rob-2 Posted July 24, 2013 Author Share Posted July 24, 2013 Its not about PSI its about CFM. What turbo? Vf40. Link to comment Share on other sites More sharing options...
RWebb Posted July 24, 2013 Share Posted July 24, 2013 Now a compressor map for the VF40 and you are set Link to comment Share on other sites More sharing options...
rob-2 Posted July 24, 2013 Author Share Posted July 24, 2013 Now a compressor map for the VF40 and you are set Not sure I have that. Is the CFM's not known? Link to comment Share on other sites More sharing options...
rob-2 Posted July 24, 2013 Author Share Posted July 24, 2013 I would guess the answer to this would be fairly complicated and would be subject to the increased volume of air being pushed into each cylinder under boost--way over my head. Why are you wondering this? Attempting to determine actual stress on motor components. Link to comment Share on other sites More sharing options...
prodrifterx Posted July 24, 2013 Share Posted July 24, 2013 I wish compressor maps were easily available on the ihi turbos like Garrett releases on their turbos. A compressor map is very useful. Link to comment Share on other sites More sharing options...
