boshmoe Posted July 21, 2013 Share Posted July 21, 2013 The dash storage compartment above the radio that also contains the info panel for mpg, weather, etc has popped out and will not fit back in properly. Anybody have similar issue and know how to resolve? Any help is welcome. Thanks! Link to comment Share on other sites More sharing options...
PortCityLGT Posted July 22, 2013 Share Posted July 22, 2013 The cubby and surrounding vents & trim are removable by hand. Try removing it entirely, including unplugging the info panel, and checking if anything is stopping it from being re-inserted properly. When I had mine out, it definitely took some wiggling and fine tuning for it to slide back in properly. There is a DIY thread with pictures around here somewhere, too. Link to comment Share on other sites More sharing options...
AkumaMax Posted July 23, 2013 Share Posted July 23, 2013 Pop the piece out then slide it back in. Make sure the bottom clips in first then just make a fist and lightly tap all around the unit Link to comment Share on other sites More sharing options...
chimera Posted July 23, 2013 Share Posted July 23, 2013 same issue on mine, pops out slightly top left, my fix... is I just don't look at it Link to comment Share on other sites More sharing options...
