I Donated thefultonhow Posted July 20, 2013 I Donated Share Posted July 20, 2013 So today I was driving along, minding my own business, when the car said the emergency brake was up on the trip computer (it beeps and displays a graphic on 07-09s if you have the emergency brake up while moving -- I guess for the 5EAT guys so that they don't drive with the e-brake on). It flashed up momentarily at first, then a few miles down the road it started flashing more often. It now does it whenever I shift, go over a bump, brake, etc. The BRAKE light on the dash comes on at the same time. I tried the following troubleshooting steps: 1. Tried unplugging the connector from the e-brake sensor/switch. I checked and this is supposed to make the car think the e-brake is down at all times, even when it is up. Problem still occurred. 2. Checked the brake fluid reservoir. It's at the full line. 3. Took off the shifter trim and tugged on the wire going to the e-brake switch. It fixed the problem for a little while, then it started occurring again. 4. Took apart the dash and checked the harness for places it might be shorting out. Couldn't find any before the harness disappeared behind the HVAC stuff near the firewall. Any other ideas of what to check? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 21, 2013 Author I Donated Share Posted July 21, 2013 Bump... Link to comment Share on other sites More sharing options...
510Finn Posted July 22, 2013 Share Posted July 22, 2013 Isn't the eBrake switch replaceable? Seems to me that's the problem. Sent from my Nexus 4 using Tapatalk 4 Beta 08 Spec B details Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 22, 2013 Author I Donated Share Posted July 22, 2013 Isn't the eBrake switch replaceable? Seems to me that's the problem. Sent from my Nexus 4 using Tapatalk 4 Beta See the OP: I tried the following troubleshooting steps: 1. Tried unplugging the connector from the e-brake sensor/switch. I checked and this is supposed to make the car think the e-brake is down at all times, even when it is up. Problem still occurred. So even with the e-brake switch completely out of the equation, it was occurring. Tugging on the wires a bunch while troubleshooting seems to have fixed it temporarily, but I have a feeling it will be back, so further suggestions would still be appreciated. Link to comment Share on other sites More sharing options...
