06legsleeper Posted July 17, 2013 Share Posted July 17, 2013 ok , this all started sun night .. car sat for about 6 hrs .. got into start it ran rough as hell ... let it go cel came on i scanned it came up cyl 3 misfire .. im like wtf .. cleared it .. restarted her, same shit .. so i figured id make my way home slowly ( was only 5 miles away ) was takin it easy but this dude cut me off .. so i gave it some gas ( about 2500 rpm ) and it lvled out like the miss was never there, ran smooth as silk all the way home next morning no issue to and from work .. that night was on 95 going to the art museum to hangout with fellow subbie peeps .. and code is back i pull off 95 go to make a u turn .. and code is gone ... errrr wth .. today was good ... now i have new plugs, buying just redone injectors off my buddy ( he went top feed ) from what ive looked up and seen i think im on the right path ... car has 57k miles , old man owned it before me so i doubt it ever seen boost lol ... had 51k when i bought it 9 months ago. im holding boost fine ... no oil burnage ( thats abnormal ) pcv system is fine no sludge or oil in it im going to switch out the coil packs when i do the plugs and see if it follows.. but other then that .. anything else i should be looking for . any inpt would be greatly appreciated . thanks all Link to comment Share on other sites More sharing options...
rob-2 Posted July 17, 2013 Share Posted July 17, 2013 How many tanks of gas have you consumed? You can quickly move the injectors around and see if the code follows. Link to comment Share on other sites More sharing options...
06legsleeper Posted July 18, 2013 Author Share Posted July 18, 2013 just started on this fillup .. i filled up sat problem started sun around 5 and the misfire is so random sometime i drive 40 min to a hr and nothing other times happens so as its warmed up very odd and when i jump on the gas its gone bad gas maybe ? im at a half tank maybe ill top off at a diff station today and see Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 18, 2013 Share Posted July 18, 2013 Do you have a VAGcom cable and a laptop? You could pull an LV to check the overall 'health' of your engine. Secondly, check this link out: http://forums.nasioc.com/forums/showthread.php?t=2318069 . Plenty of info to troubleshoot a misfire. Link to comment Share on other sites More sharing options...
JermTheElf Posted July 18, 2013 Share Posted July 18, 2013 Bad gas would leave you with misfire on all 4 cylinders. May be a sticky injector, but then it could be a plug or coil going bad. Link to comment Share on other sites More sharing options...
06legsleeper Posted July 18, 2013 Author Share Posted July 18, 2013 my buddie has software and a cable .. just been so damn hot here i cant even sit in the car for more then 10 min .. with the heat index today is 102 .. guess ill get a new pack just to make sure when i do the plugs ill change it up now after work today it instantly started with a misfire ... cleared it , came back ...drove 2 blocks and it ran fine .. guess im going to replace the pack, injector and all the plugs shortly Link to comment Share on other sites More sharing options...
rob-2 Posted July 18, 2013 Share Posted July 18, 2013 I wouldn't keep driving around if you're getting knocking, given enough you're going to pit a piston or worse... Link to comment Share on other sites More sharing options...
06legsleeper Posted July 18, 2013 Author Share Posted July 18, 2013 if it runs fine tomm ill drive it ... its my dialy and have to get my kid from summer camp so not much choice in the matter really .. if it pops a code i have my scanner ill clear it and i work 5 blocks from my house so if i have to ill walk to work and back then get my kid Link to comment Share on other sites More sharing options...
LankyA Posted July 22, 2013 Share Posted July 22, 2013 I've been having what I think is a similar issue. When I am accelerating slowly it feels like the car hesitates. It pulsates and the MPG gauge goes back and forth like a windshield wiper. When I push it or keep the RPMs above 3k it doesn't do the hesitation. I'm thinking its my spark plugs. I ordered them from Amazon and plan on putting them in tomorrow. Link to comment Share on other sites More sharing options...
rob-2 Posted July 22, 2013 Share Posted July 22, 2013 if it runs fine tomm ill drive it ... its my dialy and have to get my kid from summer camp so not much choice in the matter really .. if it pops a code i have my scanner ill clear it and i work 5 blocks from my house so if i have to ill walk to work and back then get my kid Keep in mind clearing the code does NOTHING to resolve the problem. Best case, it's very minor and no long term problem, and worse case you're on the path to a major motor failure. I've got a kid, dog, lady, and I wouldn't risk a $5-6k motor build for connivance. Drop the $70 and get the shop to have a rental car for you for a few days while they inspect. Or better yet get to a shop that works saturday. I'm surprised you're willing to drive around with a consistent CEL. Link to comment Share on other sites More sharing options...
06legsleeper Posted July 22, 2013 Author Share Posted July 22, 2013 issue fixed ... my plugs where in bad shape ... number 3 plug. was cracked all the way from the top of the plug to the socket part on the white ceramic part .. i replaced the pack anyway as i bought a new one just incase so ... issue resolved and for the record it wasnt a constant cel light Link to comment Share on other sites More sharing options...
JermTheElf Posted July 22, 2013 Share Posted July 22, 2013 You put in OEM plugs correct? Link to comment Share on other sites More sharing options...
LankyA Posted July 23, 2013 Share Posted July 23, 2013 You put in OEM plugs correct? Will this make a difference? Link to comment Share on other sites More sharing options...
JermTheElf Posted July 23, 2013 Share Posted July 23, 2013 Will this make a difference? Yes. You should ONLY use the OEM NGK Iridium plugs. Link to comment Share on other sites More sharing options...
06legsleeper Posted July 23, 2013 Author Share Posted July 23, 2013 yes.. i used oem plugs, i didnt even go one step colder just oem iridium Link to comment Share on other sites More sharing options...
LankyA Posted July 25, 2013 Share Posted July 25, 2013 Yes. You should ONLY use the OEM NGK Iridium plugs. Ok good. Those are the ones I purchased. Thank You. Link to comment Share on other sites More sharing options...
06legsleeper Posted July 27, 2013 Author Share Posted July 27, 2013 np at all ... now this is a update on what happened car ran good for a few days with the new plugs . still i could kinda hear a miss every now and again .. after 2 days or so . i got the code again .. im like wtf ...i cleared it it was fine for 3 more days. i go out lastnight . cold start . pop the code again ..clear ir it ran fine all the way home .once warm (kinda still hearing the miss though ) i got a compression and leak down test done (buddy of mine did it ) free of charge all the results come back good . so i get a injector from glanzman subbie ... 140 bucks ... ripoff bastards..lol i replaced the pack , all the plugs , this was the only thing left.or to rule out.. put the injector in .. start her up... runs like a kitten.... this miss i was slightly hearing is now gone .. and it was a cold start . ran like it should .. i sprayed every line and gasket with brake cleaner the idle never once changed .. wasted 2 cans just to make sure .. odd how 1 injector could go like that .. makes no sense to me .. every car i ever owned never once had a injector fail so randomly prob could have saved myself 80 bucks on the pack if i would have switched 3 to 1 and seen if it followed.. but least now i know its all new so just wanted to update what happened Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 5, 2013 Share Posted August 5, 2013 I would bet that it will show up again. It will be the coil pack on #3 cylinder and the issue is bad contact between the plug into the coil pack and the coil pack. Take needle nose pliers and slightly twist the three pins inside of the coil pack so that they will make better contact and your misfire issue should go completely away. I did this with all 4 coil packs after chasing a misfire for about a week. I've had not a single issue with the misfire again in 4 months since. Link to comment Share on other sites More sharing options...
