JoeC99 Posted July 11, 2013 Share Posted July 11, 2013 Hey guys, so I was backing up today with my wheel turned all the way. Due to the wheel being turned I had to give it more gas, as I did so, my power steering went out, then my dash lit up with about every light you get once you then your car on. First reaction: shut the car off. Gave it a minute then I restarted, the car was fine. Any ideas? Link to comment Share on other sites More sharing options...
12sechatch Posted July 11, 2013 Share Posted July 11, 2013 My money is on your battery dying or a loose connection on your battery terminals. What year car? Has the battery ever been replaced (when?)? Check your terminals for corrosion, loose connections, etc. Link to comment Share on other sites More sharing options...
AZP Installs Posted July 11, 2013 Share Posted July 11, 2013 Ditto what he said above. Usually that means the alternator has an issue but if you restarted and it's running without issue I wouldn't worry. Check and make sure the belt is still on snuggly. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
The Little Red Wagon Posted July 30, 2013 Share Posted July 30, 2013 Check your terminals for corrosion, loose connections, etc. I'm gonna agree on this one. Intermittent electrical problems that I've seen are usually no fault of anything other than a loose connection. Just go under the hood and start wiggling things to see if you can find anything loose. If you've got a multimeter, check the charging circuit as well, and make sure that you've got good continuity through the whole thing. Link to comment Share on other sites More sharing options...
