super-roo17 Posted July 10, 2013 Share Posted July 10, 2013 Im looking to instal some racing seats. Im doing this for multiple reasons one i have ro replace the motor for my passenger seat fpr the second time and my seats are ripped and kinda shot. So looking to upgrade.. has anyone put races ng seats in and if so how do i bypass the seat belt alarms and airbags? Link to comment Share on other sites More sharing options...
thisisthenewsic Posted July 10, 2013 Share Posted July 10, 2013 The driver side is easy. Just put a resistor in the harness for the seat belt plug. Passanger side causes a ton of problems with the passenger occupancy sensors. It'll turn on your airbag light on the dash, the chime will constantly go off, and the passenger side air bag will always be off. I put recaro spg seats In my car with harnesses and a harness bar. My car is driven once or twice a month and I deleted the chime in the immobilizer box. I don't recommend doing it if you daily your car and have passengers alot. But it's up to you. Link to comment Share on other sites More sharing options...
super-roo17 Posted July 12, 2013 Author Share Posted July 12, 2013 is the immobilizer box on the gas pedal?? if so that would fix the damn chime from when I put a quick release in... and how did you fix the occupancy sensor? with a resistor? Link to comment Share on other sites More sharing options...
super-roo17 Posted July 12, 2013 Author Share Posted July 12, 2013 although, I guess if I knock out the chime I don't need to worry about the occupancy sensor do I? Link to comment Share on other sites More sharing options...
thisisthenewsic Posted July 12, 2013 Share Posted July 12, 2013 The immobilizer is on the steering column under the dash by the pedals. If u delete the chime u won't hear it but it also does not give u a working passenger airbag. Because the occupancy sensors are not there so the passenger airbag off light will always stay on. Hense why I don't recommend it of u drive people alot. Like I said. My car gets driven only a few times a month tho I didn't have a problem not having a passenger air bag. Link to comment Share on other sites More sharing options...
thisisthenewsic Posted July 12, 2013 Share Posted July 12, 2013 Also, do not try n put a resistor in one of the plugs for the passenger side. If its not the right resistance, it could possibly set of the air bag system. And I have heard no info from anyone else about the right resistance nor heard of anyone doing thing so I don't recommend it. Link to comment Share on other sites More sharing options...
super-roo17 Posted December 31, 2013 Author Share Posted December 31, 2013 It sounds to me that if you just pull the chime, I wont need to worry about resistors... the car is a DD but I don't usually have passengers. I plan on going with some racing harnesses and a 4 point belt. so ill be held in nicely incase of a front end accident. what did you get for mounts too?? I hear I should go with the same brand mounts as the seats. but I hear planted is a better route.. just wondering how you went about it. thanks for your help btw! Link to comment Share on other sites More sharing options...
super-roo17 Posted December 31, 2013 Author Share Posted December 31, 2013 also how did you install your harness bar? thanx! Link to comment Share on other sites More sharing options...
