lgtvf52 Posted July 6, 2013 Share Posted July 6, 2013 So I am in the middle of doing a tgv delete and of course I totally forgot to release fuel pressure buy pulling the fuse and running it til it stops, I have the whole intake manifold, intercooler, tgvs unbolted, was just getting ready to pull injectors and just remembered that and wanted to know is there any other way of releasing fuel pressure without having to put everything back together?? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 6, 2013 Share Posted July 6, 2013 I guess you figured out to put a rag over the rubber hose on the shock tower before you released the hose from the tube ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lgtvf52 Posted July 6, 2013 Author Share Posted July 6, 2013 I guess you figured out to put a rag over the rubber hose on the shock tower before you released the hose from the tube ? What do you mean? Can I release the fuel pressure from the yellow/green clip? Sent from my SPH-L710 using Tapatalk 2 Link to comment Share on other sites More sharing options...
lgtvf52 Posted July 6, 2013 Author Share Posted July 6, 2013 I guess you figured out to put a rag over the rubber hose on the shock tower before you released the hose from the tube ? What do you mean can I release the fuel pressure from this yellow/green clip? Sent from my SPH-L710 using Tapatalk 2 Link to comment Share on other sites More sharing options...
