98legacygtPOS Posted July 6, 2013 Share Posted July 6, 2013 My legacy is throwing a P0740 (torque converter solenoid malfunction) its really confusing me because my car is a manual (no torque converter) and i checked the transmission code already to make sure it came with a manual from the factory. Is there any way to fix this? I've already searched for at least an hour and couldn't find anything. Link to comment Share on other sites More sharing options...
1055 Posted July 6, 2013 Share Posted July 6, 2013 You may have a ground issue at the pcm. The only difference between the automatic and manual ecu is a single pin that is either grounded or left open. Pull up model specific wiring diagram, find pin. See what its supposed to be. Hopefully success. Link to comment Share on other sites More sharing options...
ehsnils Posted July 6, 2013 Share Posted July 6, 2013 Have you tried to reset it? It's entirely possible that the ECU has had a brain fart. In many cases the same software is running on all ECUs but the behavior depends on parameters loaded at the factory. Link to comment Share on other sites More sharing options...
98legacygtPOS Posted July 6, 2013 Author Share Posted July 6, 2013 OK thanks guys I'll try both these next as soon as I can and report back. Sent from my SCH-I545 using Tapatalk 4 Beta Link to comment Share on other sites More sharing options...
98legacygtPOS Posted July 9, 2013 Author Share Posted July 9, 2013 Reset the ecu today and it worked! I feel really stupid that it was this easy but thanks for the help guys! Sent from my SCH-I545 using Tapatalk 4 Beta Link to comment Share on other sites More sharing options...
