rmhuntley Posted July 1, 2013 Share Posted July 1, 2013 I changed the plugs on my Legacy today, and the idle rent up to about 2k. to change the plugs, I removed the Air intake, and also the battery. just to get easier access. Any ideas? Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 1, 2013 Share Posted July 1, 2013 What plugs did you use? Does it stay idling at 2k? It is normal for the engine to idle around 2k after resetting the ecu. Then as it warms up and gathes info the idle drops back to normal levels. Also, it is supposed to intially idle a little high then drop down. Link to comment Share on other sites More sharing options...
rmhuntley Posted July 1, 2013 Author Share Posted July 1, 2013 stays idling at 2k. I used NKG BKR6E-11 Link to comment Share on other sites More sharing options...
rmhuntley Posted July 2, 2013 Author Share Posted July 2, 2013 the problem seems to have corrected itself. Link to comment Share on other sites More sharing options...
Ihada147 Posted July 2, 2013 Share Posted July 2, 2013 i had the same issue when i replaced my plugs also, now it only does it every once in a blue moon. also used ngk platinums gapped at .044 or .045, can't remember which one exactly but it was the spec on the autozone computer. Link to comment Share on other sites More sharing options...
jp233 Posted July 2, 2013 Share Posted July 2, 2013 The only plugs werf a sheet on these 2.2 n/a cars are the NGK BKR6E Cheap and so super easy to replace. I set my gap about 0.38" and let it open up over time. At 25k it is like clockwork where it will surge and lope at red lights with Max AC on. Time to change them. There is a ton of info over at legacycentral.org Link to comment Share on other sites More sharing options...
