hal9e3 Posted August 19, 2006 Share Posted August 19, 2006 Finally finished this 'little' project. Between the prep work, sawing off the old flares, painting and reinstalling the mufflers, installing the tips and curing the paint it took me about 6 hours. Pictures in order are: 1) Old tip sawed off 2) Tip from inside showing muffler outlet pipe 3) Side view 4) Back view 5) Closeup view underneath 6) Whole view underneath showing Lachute res/Y as well I'll post a writeup (it's pretty easy actually) and a vid later. I was amazed to find that the Borla tips actually changed the exhaust sound! It kinda purrs now. Haven't opened it up yet. Link to comment Share on other sites More sharing options...
PGT Posted August 19, 2006 Share Posted August 19, 2006 got before/after of the finished product? they look stock to me, but I'm probably missing something Link to comment Share on other sites More sharing options...
mattg Posted August 19, 2006 Share Posted August 19, 2006 nice work Link to comment Share on other sites More sharing options...
dvdt Posted August 19, 2006 Share Posted August 19, 2006 Borla tips look very simular stock, Slightly larger if I remember correctly. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted August 19, 2006 Share Posted August 19, 2006 Nice. It looks really clean. It looks like it comes from the factory that way. I like the fact that it is more flush with the bumper than the OE. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 19, 2006 Author Share Posted August 19, 2006 PGT, got brochure? Yeah, they're pretty similar. About 1/2" wider and 1/4" taller. That's the beauty of this setup tho. You can put ANY Borla tip with a 2.5" inlet ID and clamp on our mufflers the same way I did mine. Also, if you check the tip_under1 photo you'll see that I have the tips set about 1" out from their most-tucked-in setting. I would estimate you could move the tips at least 2" further out and maybe more if you're looking for a more arresting visual statement. Link to comment Share on other sites More sharing options...
OhBe1 Posted August 20, 2006 Share Posted August 20, 2006 Was considering this for our NA OB, but cutting off the turned down section of the tips would leave too little to clamp on to - I'd have to pay someone to weld. So I found LGT cans for cheap. Not that much difference from the rear, but yours look better in profile. And the paint makes a dramatic difference. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 20, 2006 Author Share Posted August 20, 2006 The pictures really don't do it justice. The more I look at it the better I like the result. Went to the local Legacy/OB GTG last night and I can see why sedan owners aren't overly impressed. The tips are now located about where they are on a sedan, but are at least 1" further out than they are on a wagon. Link to comment Share on other sites More sharing options...
hal9e3 Posted August 20, 2006 Author Share Posted August 20, 2006 Here's a couple of comparison pics. The first one is a little far away but it does show the difference between the Borlas and stocks. The second is a really good side shot: http://img112.imageshack.us/img112/2004/dfwgtg3oz9.jpg http://img50.imageshack.us/img50/1818/dfwgtg4ol3.jpg Link to comment Share on other sites More sharing options...
hal9e3 Posted August 21, 2006 Author Share Posted August 21, 2006 If the oval tips are too much like the stockers for your taste Borla also makes a round tip. It looks like only the tips I bought and these tips have a clamp-on design. Oh, well... Link to comment Share on other sites More sharing options...
Guest Posted November 14, 2006 Share Posted November 14, 2006 I can't open pix #3, #5 and #6 Link to comment Share on other sites More sharing options...
hal9e3 Posted November 14, 2006 Author Share Posted November 14, 2006 I can't open pix #3, #5 and #6 Works for me:confused: I need to post some new pics. I moved the tips out about 1" and they look more distinctive now. Link to comment Share on other sites More sharing options...
Guest Posted November 14, 2006 Share Posted November 14, 2006 Seriously doesn't for me!!! Can you please reattach them in another post... Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted November 14, 2006 Share Posted November 14, 2006 Looks great. got a couple of quesions, I am thinking of doing something similar later on... How do you like the lachute pieces? is there highway exhaust droning noise? does it fit fairly well without difficulty? What paint did you use for the mufflers? mine are painted, but the paint isn't holding up that well... I am thinking about changing the tips on mine, as well, to the Magnaflow double-walled round slash-cut tips... do you recommend welding them on, or clamping them on as you did (aside from paying someone to weld it... I suppose that somewhat depends on how much space there is...) Link to comment Share on other sites More sharing options...
Guest Posted November 20, 2006 Share Posted November 20, 2006 Would someone please repost these pics? They really don't work on either of my computers. Link to comment Share on other sites More sharing options...
hal9e3 Posted January 22, 2007 Author Share Posted January 22, 2007 OK, bigger pictures posted [ame=http://flickr.com/photos/34172478@N00/sets/72157594493225954/]MufflerPics - a set on Flickr[/ame]. These are the old pictures with the tips in their original position. I have moved them about 1" further out since these were taken. Hopefully I'll have a bunch of new pics next weekend with all my new stuff, and I'll update the muffler pics while I'm at it. IWSS, the Lachute went on OK but not without some difficulty. The bolts were too short where the res connects to the Y, and it didn't include new bolts where it connects to the DP either so those were too short as well. I had to make mini spring compressors out of tie wraps to get it connected:( It also requires an additional gasket to go along with the donut, and getting it seated properly was a PITA. After everything was said and done it's a nice piece tho, as long as I never have to take it off and put it back on:) I'm very happy with the sound. Just a touch of extra growl, partly from the Lachute, partly from the Borla tips. I used hi-temp paint which can be bought at Pep Boys et al, and it seems to work fine and may even be overkill that far back in the exhaust system. Just be sure and get the mufflers VERY clean before painting them and you shouldn't have any problems. I'm lazy and I wanted to be able to easily revert back to stock so I went with clamp-on tips, which definitely limits your choices. Link to comment Share on other sites More sharing options...
