prelude Posted December 30, 2005 Share Posted December 30, 2005 First of all, thanks to guys who shared their ideas here! Remove the ashtray is the first step. I did not trim the screw hole all the way but leave some of them, will use them as foundations to secure the clock in place. HOT GLUE Time! http://legacygt.com/forums/attachment.php?attachmentid=13098&stc=1&d=1135982571 The hot glue is much stronger than I thought. Make sure the angle of the clock is right before the glue cool down. Then, use the craft material from my daughter, cut a piece of black form thing to fill the gap. DONE! Cost: almost free…. Link to comment Share on other sites More sharing options...
konrad Posted December 31, 2005 Share Posted December 31, 2005 that's not bad. what did you do with wires? Link to comment Share on other sites More sharing options...
prelude Posted December 31, 2005 Author Share Posted December 31, 2005 that's not bad. what did you do with wires? I have not finished yet, check this out, http://legacygt.com/forums/showthread.php?t=23059&highlight=usdm+clock maybe this weekend.... Link to comment Share on other sites More sharing options...
CombatCQB Posted July 24, 2006 Share Posted July 24, 2006 Has anyone else tried this? I think the glue doesn't hold up in summer heat cause mine fell off the first day in the sun. Link to comment Share on other sites More sharing options...
chuckzul Posted July 24, 2006 Share Posted July 24, 2006 I hope you have better luck than I did. I thought a hot glue gun using that ultra strong black glue would work too...and it did....for about a week, until vibration or heat broke it off. I had to just suck it in, and buy a new shift panel (about $60) and that accursed $187 piece of plastic from AVO. If you really feel compelled to glue it, use some strong ass epoxy. That might work. Link to comment Share on other sites More sharing options...
prelude Posted July 24, 2006 Author Share Posted July 24, 2006 I have used hot glue on my central vent-bezel to glue a 7" LCD screen, and this clock. The hot glue on LCD broke off 3 months later after hot weather arrived. The glue on clock is still ok. I use 5 mins epoxy on my LCD screen and all I can say is it does the job very well, very STRONG!! Link to comment Share on other sites More sharing options...
CombatCQB Posted July 27, 2006 Share Posted July 27, 2006 I ended up wraping epoxy putty around the screw posts and redrilled it to mount the clock. It's not hard and I can remove it later for repairs. Link to comment Share on other sites More sharing options...
imblaze89 Posted August 18, 2013 Share Posted August 18, 2013 What is everyone using to fill the gaps? Some kind of foam? Link to comment Share on other sites More sharing options...
JermTheElf Posted August 19, 2013 Share Posted August 19, 2013 They make a JDM trim piece for this. Link to comment Share on other sites More sharing options...
imblaze89 Posted August 20, 2013 Share Posted August 20, 2013 Its like 100 bucks tho, i just want a cheap alternative Link to comment Share on other sites More sharing options...
JermTheElf Posted August 20, 2013 Share Posted August 20, 2013 Its like 100 bucks tho, i just want a cheap alternative You're gonna get something that looks half the quality though. I fiberglassed mine down there and because of the flex required to put the shift boot in it cracked. It's much easier to just buy the panel. Link to comment Share on other sites More sharing options...
imblaze89 Posted August 21, 2013 Share Posted August 21, 2013 Yeh that's what happened wen I fiberglassed my cubby bezel. Seems like this guy using foam is a good alternative for cheap, if I could ever do it and make it look right Link to comment Share on other sites More sharing options...
AkumaMax Posted August 27, 2013 Share Posted August 27, 2013 Oh thats pretty neat. Didn't even think about going that route. Anyway. If you need I can make a jumper harness that will reach down there. Link to comment Share on other sites More sharing options...
